Old 04-09-2014, 02:11 PM   #1
Texasbigblock
Texasbigblock's Avatar
One ton disc brakes
Hey yall,
I'm from the 67-72 side of the forum but I need some help from the 73 up guys. I just got a 80ish model disc brake front end from a single wheel one ton to put under my 1970 dually. My question is, will 73-87 dually front hubs/rotors fit on the single wheel spindles or will I need to change the spindles out also? I want to run my dually offset front wheels so they'll match the rear.
-Scott-
1970 C10 shortbed 396
1969 C30 dually flatbed "Vidalia"
Texasbigblock is offline   Reply With Quote
Old 04-09-2014, 02:43 PM   #2
Texasbigblock
Re: One ton disc brakes
Reading back through that, it was kinda confusing, lol. Basically, what I'm asking is... How do I put dually style wheels on a 73 and up 1ton single wheel style front end?
-Scott-
Old 04-09-2014, 03:55 PM   #3
walkerb
walkerb's Avatar
You need the dually hubs and everything else will fit, if I remember correctly. Its a dana 60 correct? The pass side inner u-bolt will be 2 bolts instead of a u-bolt.
The dually hubs are very easy to come by. The singles that you have are VERY HARD AND EXPENSIVE to get.
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 04-09-2014, 04:12 PM   #4
Texasbigblock
It's a 2wd front end. I guess I should be calling them rotors rather than hubs.
-Scott-
Old 04-09-2014, 04:45 PM   #5
rs72z
rs72z's Avatar
When I converted my 78 3/4 to a dually I had to change spindle also, the 3/4 spindles won't work with the dually hubs/rotors.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 04-09-2014, 05:06 PM   #6
Texasbigblock
This one is already a 1 ton but its a single wheel. I wonder if the 1 ton single and dual use the same spindles.
-Scott-
Old 04-09-2014, 09:15 PM   #7
Texasbigblock
I found the answer finally. For anyone else with this question, it seems that the same spindles were used on DRW and SRW trucks so the rotors are interchangeable without changing the spindles.
Thanks!
-Scott-
Old 04-10-2014, 09:46 AM   #8
rs72z
rs72z's Avatar
Good luck. I know they wouldn't interchange on mine. 1 ton single wheel could be different, not sure on it.
___________________
78 ccsb dually
5.3
4l60e
