![]() Join Date: Apr 2012
Can someone help me decode a SPID (gear ratio)
I called a guy about a rearend and he's not sure what he has. He gave me this code from the SPID; 4680AF.
It's from a 1/2 ton 69'. Hopefully somebody can give me the info on this. Thanks. |
Re: Can someone help me decode a SPID (gear ratio)
4680AF=4G80AF= G80 posi trac.
Sorry don't know what ratio.
CHEVY/GMC VIN DECODERS |
Thanks, the guy doesn't want to look under the truck for me. I'll try to get out to see for myself this weekend.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
If you know the original rear end is still in the truck what engine and trans was it built with because because I can check a chart for you and tell you what it was buolt with.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
