69 c/10 lwb fleetside
gas hand not working
my 69 c10 just started having gas hand problems it stays good ways past full i can unplug the wire on the sending unit and it goes alittle ways further. is this a ground issue or what?
69 lwb fleetside ![]() 67 swb fleetside ![]() (2) 72 lwb fleetside 50 swb no bed ![]() 65 impala ss ![]() 65 1 ton flatbed ![]() |
Re: gas hand not working
no ideas?
try describing the issue in detail... details equal answers
Ed will be known as the Tiger Woods of the integration business |
![]() Join Date: Jun 2000
What's a gas hand? Are you asking about the gas gauge?
Easy Does It
im curious too, my gas hand stays above full, even with the brown wire unhooked from fuse panel, not sure if its the sending unit in the tank or gauge itself
They mean gas gauge needle..
1971 C10 - LWB shortened to SWB, welded in my C notch, reinforced trailing arms with 3/16 plate, new cpp 5" rear drop springs, 2" drop blocks, ece super panhard kit. Cpp drop spindles, 2 inch front springs, 5.3/4L80E I call it Bruce Banner.. |
As with anything electrical on our trucks, start tracing wires one at a time. Eventually you'll probably find an issue with one of them. Use a spare chunk of wire of similar gauge with a couple alligator clips on it to test between 2 contact points to see if the original wire is bad. If it is, replace it and see if that solves the problem... Oh yeah, you can do that "ohms" thing too, but my elevator doesn't go that close to the top floor so I take the simple way.
