Gas fumes in cab
Recently acquired a '71 C10 Custom with the gas tank behind the seat. There is a relatively strong gasoline odor in the cab which I obviously want to get fixed IMMEDIATELY! Upon inspection I found old, tired out silicone caulking between the filler neck and the tank. I believe this is the source of the vapor leak. Aside from removing tank and filler neck to have it professionally soldered or braised, it there a product (better than silicone) which I could use to seal the area? I'm thinking something similar to JBWeld or MarineTex but must not be gas permeable.
Thanks!!! |
#16876
Re: Gas fumes in cab
Check both the filler neck and the sending unit gasket. My '71 always use to stink if I filled the tank all of the way. Lucky for me I cant afford to. Make sure you have a vented gas cap so you are replacing the cheap stuff first.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
#3 | |
68 GMC 2500 stepside LWB 250CI |
Mine smelled until I put sealer on the sending unit screws as well. The gasket sealed, but the screws weeped... No smell now. Worked for me.
past trucks: 1980 C-10 Silverado SWB 1961 C-10 custom cab LWB 1966 C-10 custom cab LWB |
Mine had the sending unit gasket/or ing leaking. Replaced it and the retainer ring. Problem was solved. But I failed to realize the PO before had used a non vented cap so it started back up leaking again. Replaced the cap and the sending unit quit leaking. Seems fine now. Been about 3 months without any more issues.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
my 71 had a strong smell of fuel when I purchased it so I pulled the tank out and found heaps of pin holes in the bottom of tank. Had just started to rust through so replaced with a new one and problem solved
I'm glad to see this thread. I ordered a new seal a couple of weeks ago. No I have some other things to look at while I'm working on this.
