I am curious on the setups on where an automatic transmission crossmember was used....
What did you use to mount the tail to the crossmember?? I have heard many things but they haven't worked for my swap, SBC 350 and the nv3500 (93 Silverado). Any extra input would be greatly appreciated, as well as makeshift mounts with pictures.... |
Re: 4those who have a nv3500 5speed....
I am running a '93 silverado nv4500 on a th400 cross member with a poly mount designed for the silverado. The only thing I had to do was move the cross member up about an inch and a half and redrill the holes. The mounts that go to the top of the frame are quite a paint to drill out with the body on. The holes for the mount are the same.
This mount http://www.summitracing.com/parts/pt...93/model/c2500 |
Ugly, thank you
