Old 04-09-2014, 07:06 PM   #1
grs
Ignition Switch Trouble
I can start my 64 with my house key, or any key. Would you say the switch is bad , or the cylinder? I just put the house key in a little bit, and turn it , and it starts.
grs is offline   Reply With Quote
Old 04-09-2014, 07:12 PM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Ignition Switch Trouble
I would say its wore out.. If you think its original, I would replace it.. I did the same thing on mine and got a new set of keys with it.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 04-09-2014, 07:20 PM   #3
tincan1966
tincan1966's Avatar
To actually answer your question- the lock cylinder is bad, not the switch itself. You can order replacement cylinders with keys from most of the vendors, and can also get complete sets that will re-key the whole truck.
I am not sure which year started it, but some of the switches actually have 4 positions, and unless you turn it back counterclockwise all the way to the "lock" position, you will be able to restart it from "off" without the key. if yours does not have the "lock" position, then it is most likely worn out and should be replaced for vehicle security.
tincan1966 is offline   Reply With Quote
Old 04-09-2014, 07:34 PM   #4
luvbowties
luvbowties's Avatar
Smile Re: Ignition Switch Trouble
...agreeing with tincan: these pkps were made during years where u could drive w/out keys--during years u could trust people. My dad once drove a stranger's truck out of the parking lot of a chain-grocery store, and got a couple of miles down the road on the way home, and suddenly realized a radio had miraculously appeared in the dash--he always bought new vehicles, stripped: 6-cyl., straight drive, no radio OR heater, and with blackwall tires. IIRC, he could trade each year for about $75-$100 total difference--when total cost of a new car was ~$1400-$1700(1953-1958's I remember most clearly, all Chevies of course.)
s
luvbowties is offline   Reply With Quote
Old 04-09-2014, 08:46 PM   #5
gimmy 64
this does have an advantage though. when I was having trouble with my starter. if I would go to a store I would park , pull out my key --still running and lock the door and go to the store.and if you loose your key just put your wife's key in the ignition and go LOL
gimmy 64 is offline   Reply With Quote
Old 04-09-2014, 09:22 PM   #6
grs
I wonder if I could have my cylinder repaired?
Old 04-09-2014, 10:31 PM   #7
66Submarine
66Submarine's Avatar
If it is a four position switch it's working like it should--I have one like that in one of my trucks. If it works like that, then you turn the switch all the way to the left (another click past off) and it will be "locked"; you'll need to use the correct key to turn it back to start it.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 04-09-2014, 10:41 PM   #8
BADAZ chevy guy
BADAZ chevy guy's Avatar
Just curious... Have you tried starting your house with your truck key? Cause THAT would be AWESOME!!
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline   Reply With Quote
Old 04-10-2014, 03:58 PM   #9
grs
I tried to start the house, but it won't turn over.
Old 04-10-2014, 04:04 PM   #10
grs
Thanks. That worked. Saved me a lot of work. But what do you mean by 4 position switch? It does not have accessary. At least I don't think it does.
Old 04-10-2014, 07:40 PM   #11
66Submarine
The extra fourth position past off is just to lock the cylinder so it won't turn without the key in it (IME/AFAIK, anyway).
Old 04-11-2014, 12:55 PM   #12
donthekawguy
donthekawguy's Avatar
Four position would be all the way left is lock. going right is off on start. Four positions.
66 shorty
donthekawguy is offline   Reply With Quote
Old 04-11-2014, 06:59 PM   #13
ray_mcavoy
Maybe you should get some jumper cables and hook it up to another house
ray_mcavoy is offline   Reply With Quote
Old 04-11-2014, 10:18 PM   #14
grs
The Man's Kitchen - YouTube
I have a one story house. Would cables for a two story house work better?
Old 04-12-2014, 04:15 AM   #15
old cruiser
old cruiser's Avatar
Only if you hook it up to 1 story only . if you hook it up to both stories you'll double the voltage and blow your house up
old cruiser is offline   Reply With Quote
Old 04-12-2014, 10:43 AM   #16
grs
Thanks for the info. I will have my wife find some cables.
Old 04-12-2014, 05:42 PM   #17
grs
I figured it out. From left to right. Lock, off. run,and start.
