Old 04-09-2014, 08:42 PM   #1
Sixshooter44
33s on a 2wd?
What would it take to run 33s on a 2wd c10?
Sixshooter44 is offline   Reply With Quote
Old 04-09-2014, 09:56 PM   #2
mmiddle
mmiddle's Avatar
Re: 33s on a 2wd?
With a stock stance they will fit fine. A little tight up front but fine. I ran them on my 69
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 04-09-2014, 10:19 PM   #3
Sixshooter44
Re: 33s on a 2wd?
Thanks that's what I thought, I am picking up a nice longbed and want to run a set of 33-10.50 I have
Old 04-09-2014, 11:18 PM   #4
DreamRyder1963
DreamRyder1963's Avatar
Re: 33s on a 2wd?
Would you be able to run 35s with a 2 in lift on the front?
1971 Chevy C10 Cheyenne (sold for Mazda)
1963 Chevy Corvair Pro-Touring Project
2012 Mazda 3 i Sport sedan
http://www.dracoautodesigns.com/
DreamRyder1963 is offline   Reply With Quote
Old 04-09-2014, 11:36 PM   #5
mmiddle
mmiddle's Avatar
Re: 33s on a 2wd?
don't know about 35's I ran 33x12.50x15's and it was fine
Mark
Jesus is the Way!
Old 04-11-2014, 02:52 PM   #6
69GMCLonghorn
69GMCLonghorn's Avatar
Re: 33s on a 2wd?
I've seen factor 3/4 tons with the same size wheels front and back (33 x 12.50 x 16.5) and apparently they don't rub. I ran 32's in front on my 1 ton and have to "manipulate" the front fender corner on one side slightly.
69GMCLonghorn is offline   Reply With Quote
Old 04-11-2014, 03:05 PM   #7
Daner
Daner's Avatar
Re: 33s on a 2wd?
I had tall skinny 7.50x16 Lt tires on my 67 2wd when I first got it. No problems but they would rub if you turned the steering all the way. I think they were about 31-32" diameter.
Dane
67 Chevy Fleet 250/4 speed 1/2 ton
68 Chevy 250/4 speed 1/2 ton for parts
49 GMC Grain truck 235 1 1/2 ton
76 Chevy 350/4 speed 1/2 ton
Daner is offline   Reply With Quote
Old 04-11-2014, 09:31 PM   #8
72MARIO
72MARIO's Avatar
Re: 33s on a 2wd?
Having a ton of caster helps pull the wheel back in the opening to clear the front fender bottom. I have a 3" lift I had 285 75 15 and they rubbed. I kept wearing out the idler arm and upper balljoints. So I switched to 265 75 16 .
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
