07-28-2003, 09:22 AM | #1 |
HEI with tach drive
I got in a truck with I think a Mallory. Its an HEI with mechanical tach drive, there is no name or numbers on it. Its the same size as the old duel point corvette tach drive but with HEI. Anybody ever heard of one by Mallory or an HEI conversion for the corvette to HEI? The motor is a 65 365 hp vette motor or so i'm told.
Rest in Peace Ed. Thanks for all the good times. |
07-28-2003, 04:32 PM | #2 |
its all about the +6 inches
Hmmm, never heard of an HEI with the tach drive...
TTT |
07-28-2003, 04:50 PM | #3 |
Glowing since 1978
The hard part is finding the HEI, vacuum advance and mech tach drive. I believe you would find what your looking for through Corvette channels. I saw a one of these new at a corvette at carlisle show but it was pretty pricey. The conversion using a already existing dual point distributor with vacuum advance will be much cheaper.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 69 Chevy C20 Custom Camper |
07-28-2003, 05:41 PM | #4 |
Active Member
I remember Mallory making a mechnaical tach drive "transistor" distributor about the mid 70's. Never actually saw one except in Hot Rod mag believe Summit ad.
1969 C10 350 3spd 1995 GMC 3500 XC 350 dually When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin |
07-28-2003, 06:01 PM | #5 |
This one has mechanical advance,you adjust it with a set screw behind rubber plugs while the motors running.
07-28-2003, 07:56 PM | #6 | |
20' Daredevil (Ret)
Re: HEI with tach drive
07-28-2003, 08:14 PM | #7 |
Binder Rep
I know you can convert a delco window type dizzy to HEI relatively easily. IH guys do it sometimes to get HEI on an IH for cheap (alternative involves milling and stuff to make an IH dizzy from an existing HEI).
My money's on that he had a dizzy with a tach drive that he converted to HEI. |
07-28-2003, 10:27 PM | #8 |
THE QUICKER FIXERUPER
You can buy a new tach drive HEI from davis unified ignition.
07-29-2003, 05:02 AM | #9 |
English Chevy Owner
Try asking Mallory direct at http://www.mrgasket.com/mallorymain.html and go to the asktech section, I have found them to be helpful in the past.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
