Old 04-10-2014, 12:29 AM   #1
hpcgmc
hpcgmc's Avatar
disc brake kits
I'm about ready to buy a disc brake kit for my 67 GMC. I'm looking at disc brakes with 6 lug, 2" drop spindle, master cyl, power booster, prop valve, the whole deal. I'm getting ready to paint my crossmember and suspension, then re assemble it with new parts and the disc brake kit.
I've read about ECE, Classic Heartbeat, Tomsclassics on Ebay, TNT Motorsports and a bunch of others. Tomsclassics on Ebay seems to have the best price at $699.00. I really like dealing with Wes at Classic Heartbeat, but his price comes in at over $1,000.00 when you add in the power booster, master cyl and prop valve.
For those of you who have done the swap, did you use the kits? If so, what did your kit have that was really good, and what did it have that just didn't work right, or that was missing?
I've decided against using used parts off a newer truck for a number of reasons.
Thanks in advance for the input.
1967 GMC 1500 SWB. Driving this truck since I was 14.
hpcgmc is offline   Reply With Quote
Old 04-10-2014, 02:33 AM   #2
swamp rat
swamp rat's Avatar
Re: disc brake kits
Check these guys out and they also sell on Ebay.
http://www.mcgaughys-suspension.com/
Note the home page..... free shipping.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-10-2014, 10:40 AM   #3
big d's red67
big d's red67's Avatar
Re: disc brake kits
I used POL for mine,they are a vendor on this board. It's wilwood calipers with 2.5inch drop spindles and drilled and slotted rotors.
1967 swb 454 cid 700R4 trans SOLD
2006 Chevy Trailblazer SS
2013 Camaro RS convertible the wife's
Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248
big d's red67 is offline   Reply With Quote
Old 04-11-2014, 12:52 AM   #4
hpcgmc
hpcgmc's Avatar
Re: disc brake kits
Big D's - the Perf Online kit is $919, but comes with upper and lower ball joints and tie rod ends - looks like a pretty good deal, since I've gotta purchase that stuff as well. Was it a well put together kit? Any problems or complaints?
Thanks!
Old 04-11-2014, 06:50 AM   #5
big d's red67
Re: disc brake kits
No problems or complaints, great kit.
Old 04-18-2014, 11:13 AM   #6
hpcgmc
hpcgmc's Avatar
Re: disc brake kits
I see the POL kit comes with 1973-87 ball joints and tie rod ends. Do these bolt right in? Is there an advantage to using these?
I also see ads for a brake booster mounting kit- is there a bracket or plate needed to install the booster?
Thanks.
