04-10-2014, 02:55 AM | #1 |
Dirty Dingo Motor Mounts
Hy,
i'm in the middle of my 79 Suburban Restauration and i need urgent some Motor Mounts (have to Mount LQ4 this weekend) cause i get wrong ones and have no time to order (i live in Europe) Has somebody this style of mounts: http://dirtydingo.com/store/product_...oducts_id=1369 and can send me the measurements that i can rebuild them? Greets from Austria |
04-10-2014, 09:53 AM | #2 |
Re: Dirty Dingo Motor Mounts
I have these, but they are installed on my truck. Getting measurements without removing the engine would be very difficult.
I hope somebody can help you out.
Will 1970 CST10 SWB LQ4/4L80E 2004 Silverado (sold) 2007.5 Dodge Ram 2500 |
04-11-2014, 02:21 AM | #3 |
Here you go
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
04-11-2014, 02:54 AM | #4 |
Thank you so much for your help!!!
Maybe you can explain me what the & Sign Means and give me also the height of the holes from holes where the Long Screw goes trough? |
04-11-2014, 03:01 AM | #5 |
I was trying to make the measurements clear. Here you go = 4.375'' and 8.875''
My holes for the long bolt are longer (I have the newer version) measuring from the bench to the bottom of the first hole is 2.125'' and to the top is 3''
04-11-2014, 04:47 AM | #6 |
thank you very much now i can build them and mount my engine in the frame!
04-11-2014, 05:46 AM | #7 |
another question
are the plates for the long bolts in an angle welded to the bench or is the long screw direct in the middle? |
