Old 04-10-2014, 09:30 AM   #1
Houston Ben
Houston Ben's Avatar
Air Intake
Hi All,
Need some help with my air intake. As of now I have a modified stock air intake with spectra air filter attached going to the passenger side. This is fine for now but I am going to be putting in a DD high mount A/C system with sanden compressor and I wont be able to use the modified stock air intake as it appears to hug the engine too much.
The other problem I have is it seams all aftermarket stuff is for the circular MAF and not the type I have. Mine is a stick looking one that you have to drill a hole in the intake tube to put it in. Also, my MAF is wired up for passenger side so going the other direction will be too big a pain.
What is everyone using that has the same style MAF I do when they go aftermarket?
Thanks for any help!
Houston Ben is offline   Reply With Quote
Old 04-10-2014, 10:14 AM   #2
littlevictories
Re: Air Intake
i used the ebay cheapie CAI intake. It came with the adapter needed to go from the truck style maf to the diameter of the tube. I'm sure you could delete that and use the ls3 maf. I know they make a bung you can weld on so it's a super clean install.
when I have time to re-do it properly i'll make my own "kit" from a pile of spectra parts
http://www.summitracing.com/search/p...rder=Ascending
littlevictories is offline   Reply With Quote
Old 04-10-2014, 10:17 AM   #3
littlevictories
Re: Air Intake
found this:
http://www.hawksthirdgenparts.com/pr...2dOn-Bung.html
Old 04-10-2014, 12:17 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Air Intake
Which maf are u using? Is this this ls3/7 blade style?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-10-2014, 01:55 PM   #5
Houston Ben
Re: Air Intake
I will have to look it up, I'm running a 2011 5.3 truck engine.
Old 04-10-2014, 02:20 PM   #6
First c10
First c10's Avatar
Re: Air Intake
My 2011 LC9 has the blade style. I am using a spectra cold air kit designed for the 2011 Silverado truck the motor came from. May add an extension.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 04-10-2014, 02:22 PM   #7
Houston Ben
Re: Air Intake
The delphi AF10060 - Delphi Mass Airflow Sensors looks like the one I have
Old 04-10-2014, 02:53 PM   #8
First c10
First c10's Avatar
Re: Air Intake
Yep that's the one I have. Isnt that the blade style?
GO GO!!!
Old 04-11-2014, 01:33 PM   #9
Hart_Rod
Hart_Rod's Avatar
Re: Air Intake
This is the blade style:
Hart_Rod is offline   Reply With Quote
Old 04-11-2014, 01:34 PM   #10
Hart_Rod
Hart_Rod's Avatar
Re: Air Intake
Does any one think this is worth using?
http://www.hawksthirdgenparts.com/pr...ow-Sensor.html
Old 04-12-2014, 01:23 AM   #11
littlevictories
Re: Air Intake
whats wrong with the stock one? or are you using blade style? ( i though that was the benefit to the blade style, no need for a screen)
Old 04-12-2014, 07:58 AM   #12
Houston Ben
Re: Air Intake
Nothing wrong with it for me, I just need to redo my intake and am trying to find a mount or something for it to put on he aftermarket intake. Everything seems to be for the round one.
Old 04-12-2014, 10:20 AM   #13
littlevictories
Re: Air Intake
oh no, sorry man I was askin Hart why he thinking about adding a screen. I was under the impression that the blade style MAF sensor was used specifically to not have to use a straightener.
I'm new to these motors, and EFI in general so I'm just curious.
Good luck finding the right round bung for your set up.
