![]() Join Date: Mar 2010
What is everyone using for rear coil springs in their burbs?
I used regular truck coils and they are collapsing. Anyone had a similar experience?? thanx
65 burb On the road Mar 26th Finally |
Re: rear springs
We tried some "HD" CPP drop springs in place of our worn out stockers...they sucked! (way too soft) For us, a set of LMC, HD, progressive rate, 3/4T, springs gave us the ride height we were after with the capacity to handle light loads, family, or a bit of towing. Pic is of stock, LMC, and then CPP on right...
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
#3 | |
Re: rear springs
Re: rear springs
They have a higher spring rate than stock, so maybe a bit higher. Kinda would depend on what you're hauling around...larger than stock fuel cell, more seats/people, spare tire, speakers/amps, etc., here's how ours sat right after swapping in the heavier springs (no seats, empty tank). We've since added 2" drop spindles and a 1 1/2" rear lowering block...
Re: rear springs
Thanks for the info guys Looks like I need to bag it.
