Old 04-10-2014, 04:32 PM   #1
grs
How do I remove the horn ring.
How do I remove the horn ring so I can fix the horn.
grs is offline   Reply With Quote
Old 04-10-2014, 05:26 PM   #2
Casaba
Re: How do I remove the horn ring.
Pry off the center cap, then there are three screws that hold it on.
Casaba is offline   Reply With Quote
Old 04-10-2014, 05:46 PM   #3
WhippinSaw
WhippinSaw's Avatar
mine has some screws hidden in the backside of the ring
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle.
WhippinSaw is offline   Reply With Quote
Old 04-10-2014, 05:54 PM   #4
vin63
It's Better With Nitro
vin63's Avatar
OP…don't pry on anything. The deluxe steering wheel has a couple of holes on the backside of the spokes that provide access to the screws for the center cap. Once you remove the center cap, you can access the screws that attach the horn ring.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-10-2014, 06:27 PM   #5
Casaba
My error apparently, my deluxe wheel on the 66 has a snap in center cap
Old 04-10-2014, 06:56 PM   #6
1963c-10
1963c-10's Avatar
yeah...look at the back of the wheel and you'll see the two screws on either side of the wheel. Center section will come off then and give you access to the rest.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-10-2014, 07:04 PM   #7
grs
Thanks everyone. I will getter done.
Old 04-10-2014, 07:12 PM   #8
NEWFISHER
NEWFISHER's Avatar
1/4" deep socket from the backside, 3/4 for the column nut and 1/2 for the bolts that come in the wheel puller kit.....I've pulled mine a thousand times uugh
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 04-10-2014, 10:28 PM   #9
Brad54
Brad54's Avatar
The screws are either phillips, or clutch-head.
The three screws that hold the plastic ring inside the horn assembly are clutch heads.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
