Old 04-10-2014, 08:17 PM   #1
6061Apache
Factory gear ratio?
What rear gear ratio would a 1962 half ton Chevy with a 283/Powerglide have? To my knowledge, the truck is all factory. Maybe 3.38 or 3.90? Is there any markings to tell what ratio? Thanks
6061Apache is offline   Reply With Quote
Old 04-10-2014, 08:29 PM   #2
Roll'nSlo
Roll'nSlo's Avatar
Re: Factory gear ratio?
Not without popping the cover off
Roll'nSlo is offline   Reply With Quote
Old 04-10-2014, 09:21 PM   #3
windsurfsam
Put the truck on jackstands, put it in neutral and turn the tires. Count the tire rotations against the driveshaft rotations to get your gear ratio.
windsurfsam is offline   Reply With Quote
Old 04-10-2014, 09:44 PM   #4
crhyno
crhyno's Avatar
I had 66Submarine post this reply on a question I posted:
'62's had the Eaton rear ends; a smaller version of the HO-52/72 that came under 20 and 30 series trucks until '72. 3.90 was the standard ratio for them.
Later Captainfab added this:
The only other gears available for the Eaton HO32 differential are 3.38's.
Hope this helps.
crhyno is offline   Reply With Quote
Old 04-10-2014, 09:58 PM   #5
6061Apache
The truck is in a junkyard. I was thinking the automatic trucks were 3.38 and sticks were 3.90. I am trying to lower my rpm's in my 61 as cheap as I can.
Old 04-10-2014, 10:09 PM   #6
LVPhotos
LVPhotos's Avatar
RPMs not much different between the two. Are you looking for rear? Gears? Over drive? Foot off go pedal? In town or highway? Taller tires are the cheapest way!
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 04-10-2014, 10:35 PM   #7
6061Apache
Looking to drop rpm's on the highway. My thought was to swap out third members. My truck is just a cruiser. Mine is lowered 3 inches in the rear and run a 29 inch tire, running 2800 on the tach at 60. I have the original 3 speed. I appreciate any suggestions.
Old 04-10-2014, 11:01 PM   #8
Roll'nSlo
Roll'nSlo's Avatar
I have a '72 rear end in my '63 for the 5 lug and it came with 3.08. If u wanna keep the 6 lug try anything pre '72. Point I'm saying is try 3.08. Lol
Old 04-10-2014, 11:46 PM   #9
Captainfab
60-66 Nut
Turning 2800 @ 60 isn't too bad. That 283 will do that and more all day long. There should be a build code stamped on the passenger side axle tube that will tell you how it was built......52 years ago. Who knows what may have been done/changed in that time. There is a thread in the 60-66 FAQ index that has the axle build codes listed. Myself, I would just pull the cover and have a look. It doesn't take long.
Old 04-11-2014, 12:16 AM   #10
padresag
if it has a wa code it is a 3.90 and if it is a wb code it will be 3.38 if they are original. the wa or wb should be stamped on the r/s axle housing close to the centre section
ron
padresag is offline   Reply With Quote
Old 04-11-2014, 09:20 AM   #11
kieth
kieth's Avatar
3:08s' would be the ticket with 29" tires, you would be doing 65mph at 2500 rpm, the only way to change it more would be to go to a 700r4 with your 3:90 gears this would be 63mph at 2000 rpm the torque would be ok, if you currently have 3:38 you could not go to the 700r4 because the torque to the ground would be too low.
here is the chart where my information came from....keep in mind one needs around 460ft/lbs of torque to the ground to have a truck that will be a good highway cruiser (what I have) but it will not be a race truck....Kieth
TORQUETOGROUND_Master_r.pdf
If you have 3:38 r/a ratio then a transmission swap to a t5 with a .76 OD ratio would work. 451 ft lbs of torque 67mph @ 2000rpm (there are other ratios of t5's that could be selected to make sure your 283 was happy with the operating rpm.
kieth is offline   Reply With Quote
Old 04-11-2014, 10:56 AM   #12
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
If it's a powerglide then I would think the rear gear would be 3.90...Far as I know 3.38.1 was a "special package." I don't remember the gear split in the Powerglide trans.....I think it was something like 1st gear 1.86.1 and 2nd gear at 1.1...correct me if I'm wrong...my chevy has 31 inch 15's and the stock GM 12 bolt truck axle...at 2500 in 4th I'm going around 55..so I'm guessing my rear gears are 4.10.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
