79 Suburban K20 Resto&Mod
Planned:
Weld and Paint Body Inside and Outside, new Interior Frame and Axles Sandblasted and coated with POR15 Disc Brake Conversion for Rear End Cross Over STeering for Front End Upgrade to an 2006 LQ4 Engine ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Re: 79 Suburban K20 Resto&Mod
Inspiring pictures, I am going to lift of my Suburban's body too one day.
I have no garage lift like you though, only a tractor as help, and I can't lift in the roof I am assuming. I love the amount of pictures, keep it coming! Have you seen where the other two vin code places are at on the frame? They are supposed to be hidden close to the body on top of the frame. Link to my ongoing project http://67-72chevytrucks.com/vboard/s...d.php?t=567608 |
Yes Chevak20, there are VIN Codes on the Top of the Frame :-)
I have also no lift in my Garage, the Body will be done by a Shop, i have no Capacity for this work, so i have only the Engine Lifter in my Garage :-) In Sweden would be nice to have a Suburban, so much space for Offroading, in AUstria it's difficult to find some Offroad Area :-/ |
looks good.
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
Maybe one of you can help me with my swap questions, i want to connect the original mechanical gauges to the LQ4, so can i use the the sensors from the old 350 with an adapter on the LQ4 or do the PCM need the signals from Oil pressure and coolant temp?
So maybe there are some other positions that i can use for these 2 sensors? For Oil Pressure can i use the block off plate above the oil filter? (Tap a 1/8 NPT Thread in it?) And for coolant temp find some position on the cylinder head? |
Yes you use either an adapter or tap the existing hole. This Thread may help
#13 |
#14 |
After some electrical Troubles the LQ4 Runs now :-)
http://youtu.be/Ly3ap8BSC9U |
#15 |
Thanks a lot, so soon he will be back on the roads :-)
#16 |
Looks good! I like your burb!
Current Build 89 s10 ecsb 2wd 4.3/700r4 50k OG Miles Instagram- shaggin_s10 '86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt (Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD |
#17 |
coming right along
#18 |
Looks great!!
#19 |
Very nice!
#20 |
I used some F-Body Longtube Headers from Ebay, but they won't fit properly, i will change to Schoenfeld headers in the future...
With the new Bumpers on....Roof Rack next Step :-) ![]() ![]() ![]() ![]() |
#21 |
That is one awesome Suburban
#22 |
thx a lot :-)
#23 |
wow....thats a lot done in 4 months. I like it. Does it fit on the road over there??? lol!
#24 |
Thanks...was a hard time we got a baby to in May
![]() Yes it fits on MOST of the streets, here in 2,5 meters standard on big roads...i have a little more than 2,3 meters haha Just to give you an example how the burb looks in his old days as fire department car is maybe interesting for you: http://www.holztreff.at/kontakt/imag...olet_gross.jpg |
#25 |
Planning and Fabrication of Roof Rack:
![]() ![]() ![]() ![]() ![]() And the Junior is doing his first Exercises ![]() ![]() ![]() And i had still troubes with the disengagment of the clutch, hope it's now solved now i hate to dismount the big iron block ![]() ![]() |
