Old 04-11-2014, 08:55 AM   #1
Gibson
Gibson's Avatar
Question Are the doors supposed to "flex" when they close?
Hey guys,
Is the window frame of the door supposed to "flex" a little bit when the door is closed, or should the door be exactly the same profile as the body contours?
Here is why I ask:
I'm in the process of hanging new door shells (GM, according to the guy who bought them for me) with new hinges. I have the fenders off, and I have yet to install the glass and stuff into the door shells (wanted to do some test fits first). I took out the door gasket so that I could just have the door sort of "float" in the space without having anything resisting it. The issue I'm having is that even though the gap looks fine along the back edge of the door next to the B pillar, and the gap looks fine down where the bottom corner of the windshield and front door edge line up, the top of the door seems to be "inset" a bit. Almost like the door shell is not quite the same curvature as the body. I can push on it and get it to kind of flex and line up, but that just seems wrong.
Do I have something shimmed incorrectly? Shouldn't it match up exactly with the door opening?
Gibson is offline   Reply With Quote
Old 04-11-2014, 09:22 AM   #2
cory d
cory d's Avatar
Re: Are the doors supposed to "flex" when they close?
the doors fit like poo on most of these
cory d is offline   Reply With Quote
Old 04-11-2014, 09:42 AM   #3
gmachinz
No, there is always a slightly bigger gap at the top than at the bottom. I think it was at best hit or miss when it comes to aligning it from the factory. Then, if its A 4x4, cab flex adds even more of an issue to it. I always spend a considerable amount of time aligning the panels up and its always off somewhere. In the end, I focus on gaps between fenders to hood and the entire bodyline going down the side-those are the real critical areas imo.
gmachinz is offline   Reply With Quote
Old 04-11-2014, 04:00 PM   #4
Gibson
Gibson's Avatar
Cool, I'll just get them as close as I can then! Thanks guys!
Old 04-13-2014, 10:14 AM   #5
Keith Seymore
Keith Seymore's Avatar
This is true.
We shimmed, but just based on the shim packs we had taped up for the day. Every truck got the same amount of shims whether it needed it or not.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
