Old 04-11-2014, 09:07 AM   #1
Matt Cramer
Groved brake rotors - how to tell factory groves from just worn out?
I had a bit of noise from my right front wheel, so I took a look at the brake, and sure enough, there's a grove about 1/4" wide and 1/4" deep worn into the rotor. I figured it was shot and it's time to order new front rotors, but then I saw on the forum that some OEM rotors had groves from the factory. Any tips for how to tell if this is the case here, or if it's just wear and tear on the rotor?
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 04-11-2014, 09:41 AM   #2
chopnchaneled
chopnchaneled's Avatar
Re: Groved brake rotors - how to tell factory groves from just worn out?
My 68 has that groove in them, I think there is a min. thickness that you check, but i'm not sure what it is.
Maybe some one will post what it is?
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 04-11-2014, 10:26 AM   #3
ERASER5
ERASER5's Avatar
The factory groove should be a V groove, not flat bottom groove. The idea was that when the rotor was turned for smoothness and trueness, if a line was still there, the rotor was good. No line one or the other side, the rotor was scrapped.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 04-11-2014, 10:32 AM   #4
67 cst swb
67 cst swb's Avatar
Can you post a pic of the rotor?
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 04-11-2014, 01:34 PM   #5
Matt Cramer
I don't have a picture at this point - figured it was just a grooved rotor in need of replacement, and it is a flat bottomed groove, so that would indicate it's just damaged.
Just realized my misspelling in the title. No, there's no apple trees growing out of the rotors.
Matt Cramer
4.8 LS build thread
