Old 04-11-2014, 11:22 AM   #1
Houston Ben
Houston Ben's Avatar
Gas pedal swap DBW
Hi all,
My foot and leg are getting tired of the pedal location of my 2011 5.3 DBW pedal. I have seen where you can use a Corvette or Monte Carlo DBW pedal but just need to switch two wires, does anyone know what I have to do to make it work?
Thanks,
Ben
Houston Ben is offline   Reply With Quote
Old 04-11-2014, 12:02 PM   #2
dayj1
Re: Gas pedal swap DBW
Originally Posted by Houston Ben View Post
Hi all,
Thanks,
Ben
It's pin D and F that need to be swapped at the pedal connector to use a Corvette or Monte Carlo pedal. I found a new in the box GM DBW Monte Carlo pedal on eBay for $25 when I did the swap in my '57 BelAir. The GM part number is 25830024 and it usually runs around $100. There are aftermarket OEM replacement pedals available for around $60.
dayj1 is offline   Reply With Quote
Old 04-11-2014, 12:15 PM   #3
Houston Ben
Awesome, thanks Dayj1!!
Old 04-11-2014, 12:25 PM   #4
Houston Ben
One more dayj1, is the pigtail the same? Will the truck one plug into the others?
Thanks!
Old 04-11-2014, 12:38 PM   #5
Hart_Rod
Hart_Rod's Avatar
Thanks!
The connectors are the same. Just swap the two wires dayj1 spoke about.
Hart_Rod is offline   Reply With Quote
Old 04-11-2014, 01:38 PM   #6
Houston Ben
Thanks, you guys are awesome!! I do not understand all the wireing diagrams and you all are a big help!!
Old 04-11-2014, 01:51 PM   #7
Houston Ben
Is there a preference for the corvette one or monte one, or are they about the same?
Old 04-11-2014, 01:58 PM   #8
Hart_Rod
Hart_Rod's Avatar
I used the corvette one because I like the way it mounted and the plastic pedal was identical to the factory pedal in the 71/72 trucks, .
Old 04-11-2014, 02:51 PM   #9
Houston Ben
Cool, thanks again!
Old 04-11-2014, 03:07 PM   #10
Houston Ben
Just bought a corvette on for $58 on eBay!
Old 04-11-2014, 05:18 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I assume you mean the pedal, cuz if you just bought a whole vette for $58 your a god.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-11-2014, 05:30 PM   #12
Houston Ben
Lol, yup the pedal. Was supposed to be one not on
