Factory Auxilliary Spring Mount Needed
I have a complete set up for my stepside, now getting a set for the fleetside. I have the frame mounted part with the spring, but need a set of the bottom mounts that bolt on the trailing arms under the rear diff. Please see the pics.
Again....need the parts between the rear diff and the trailing arms...The two smaller plates (in the 2nd pic). Tried to put a few pics up for reference of where they mount and of what I need. The black set is the set I have currently.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 04-11-2014 at 02:53 PM. |
![]() Join Date: Mar 2012
Re: Factory Auxilliary Spring Mount Needed
I might have a pair of those. I will look tomorrow when I go out to the junkyard.
thanks lyle!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Found a set..
