04-11-2014, 06:20 PM | #1 |
Combat Inkslinger
C-30 Brakes Locking Up
Just bought an 86 C-30 with a 454. The brakes lock up on the first two or three applications in the morning or after the truck has been sitting for a few hours and then it quits. There were some front brake problems from the start, so I replaced the calipers, pads and rubber hoses. It does have a hydro booster on it and that is leaking a bit. I'm not sure if I have master cylinder problem, a prop valve problem or a hydro booster problem. Any help would be great......thanks.
04-11-2014, 07:38 PM | #2 |
Re: C-30 Brakes Locking Up
Front or rear or all wheels locking up?
04-11-2014, 07:53 PM | #3 |
My question also.
You did the fronts, plan on at least checking the rear. IMO, they don't wear as much, but due to the effort required to pull a drum, they're usually neglected. Curious, does it go away if you drag the brakes for a little bit and get some heat in them? Asking as mine get "touchy", especially if sitting for a while, (weeks). If it does sit, dragging them for a few hundred feet usually cures this. My fronts have been rebuilt, including rotors, and the rears have been inspected. Master cylinder has been replaced (bad when I bought the truck), hydroboost drips...sound familiar?
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. Last edited by donut; 04-11-2014 at 08:00 PM. |
04-11-2014, 09:32 PM | #4 |
Combat Inkslinger
All wheels locking up. I usually back up and pull forward a few times in my yard and then they stop. I do kind of gather a bit of speed and drag them a bit in the yard. After all of that they are great.
All you gotta do to make this a nice truck is.............. |
04-12-2014, 01:43 AM | #5 |
My 85 k20 does that when I first get in it, once warm they work perfect.
