Old 04-12-2014, 11:00 AM   #1
abraham.hd
Shaving my firewall, need help on AC components
Im doing an LS swap on my 72, I wanted to see if ya guys can refer me to anybody to get my firewall sheet metal filler. I know porterbuilt has them but just wanted to see if there is anyone else out there. I need ya guys honest opinions.
Also im not 100% if I want to keep my AC. I was told I could still shave the firewall and have my AC from a kit that "VINTAGE AIR" sells. But I also heard of some small ac units that go under the dashboard like under the radio or glovebox, not sure but if ya guys could please help me out and point me to the right direction.
Thank you.
abraham.hd is offline   Reply With Quote
Old 04-12-2014, 11:22 AM   #2
kvn1011
Kvn1011
kvn1011's Avatar
Re: Shaving my firewall, need help on AC components
before Nate dropped his kit
i found a guy on ebay who had the firewall filler panels
laser cut, i paid maybe 20.00 bucks shipped
kvn1011 is offline   Reply With Quote
Old 04-12-2014, 11:27 AM   #3
abraham.hd
Thanks man ill start looking in ebay.
Old 04-12-2014, 11:35 AM   #4
Scottshotrods
For your truck if you want to run the Vintage air gen IV kit for your truck.This kit will be a direct bolt in to your truck and will come 100% complete.This will have ac-heat-defrost and this kit will go under the dash of your truck.This kit will have a firewall panel that will come with the ac kit and this bolts onto your firewall.If you want a smooth look like you are asking for you can run ac bulk head for on your firewall and this will be clean option for you.If you are handy with some basic welding and can cut some sheetmetal.You can go to a local metal yard in your town and pick up a small piece of sheetmetal.Then you can cut it out and weld in yourself.This is on option and here is one more option depending on your budget you have.We make a custom firewall for your truck.
If you would like more info you can send me a p/m or e-mail me or call me
justin@scottshotrods.com
(805)485-0382
Justin
Scottshotrods is offline   Reply With Quote
Old 04-12-2014, 11:36 AM   #5
MattPSU
MattPSU's Avatar
I'm very pro Porterbuilt but I went with Infanti:
http://infantimachine.com/
Needs a little more body work.
Matt Criswell - Lyman, SC
1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank
UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE
MattPSU is offline   Reply With Quote
Old 04-12-2014, 11:51 AM   #6
low&slow
Oh man that's a good site. I would have bought from them if I knew about them at the time. I ended up making the pieces myself. Wasn't to bad to make cardboard fit the holes and trace it on metal. Cut the metal out and grind it down to fit.
low&slow is offline   Reply With Quote
Old 04-12-2014, 11:55 AM   #7
abraham.hd
Looks good, did you get the full firewall shavekit?
Old 04-12-2014, 12:01 PM   #8
abraham.hd
(805)485-0382
Justin
Thank you for your response, yes actually I was looking forward at that kit and noticed it also comes with a firewall panel. Ima do more research and come out to a conclusion on which kit ima go with.
Old 04-12-2014, 04:05 PM   #9
abraham.hd
Bump..
Old 04-12-2014, 05:36 PM   #10
MattPSU
MattPSU's Avatar
Yep. I ordered the firewall kit, the fuel neck filler and stake pocket fillers all at the same time.
Old 04-13-2014, 07:21 PM   #11
abraham.hd
Nice man thanks
Old 04-13-2014, 11:09 PM   #12
Infanti
www.infantimachine.com
Infanti's Avatar
If you decide to go with my kit, I have them in stock ready to ship.
Thanks, Gerry
Manufacture of Filler Panels
Billet washers
Infanti is offline   Reply With Quote
