Old 04-12-2014, 05:22 PM   #1
o6r1man
o6r1man's Avatar
Th350 shifting early
The turbo 350 in my 70 is shifting way to early. It makes the 1-2 shift around 3,300 rpm and the 2-3 shift happens 3,900 and I was just wondering what ya'll thought it would be? Thanks in advance!!
1970 SWB "old flame"
1967 SWB c10 sold
1972 Elcamino 496
2012 Denali HD dmax
o6r1man is offline   Reply With Quote
Old 04-12-2014, 07:00 PM   #2
myyamr7
myyamr7's Avatar
Re: Th350 shifting early
Is the detent/kickdown cable hooked up?
I don't remember if the modulator was for shift points, or shift firmness, but some are adjustable. I thought the detent was for high rpm shift points, and the modulator controlled the low shift points/firmness in drive
Mark
71 C10 Cheyenne
12 Aprilia RSV4
myyamr7 is offline   Reply With Quote
Old 04-12-2014, 07:01 PM   #3
kaycee
kaycee's Avatar
You might go down south in the performance section and ask ,have you done anything to it or did it just start doing it.Could be the govenor,could be in the valve body , could be clutchs need a little bit more info.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 04-12-2014, 10:51 PM   #4
o6r1man
o6r1man's Avatar
I bought the truck back about a year ago and it was doing it then. The kick cable is hooked up and working. The teams isn't slipping so I wouldn't think it was clutches. I can shift it manually and it will stay in that gear until I up shift..
1967 SWB c10 sold
1972 Elcamino 496
2012 Denali HD dmax
Old 04-12-2014, 10:56 PM   #5
litew8
litew8's Avatar
x2 for the modulator. I'd check/replace it to start with.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 04-13-2014, 10:24 AM   #6
o6r1man
o6r1man's Avatar
I did that yesterday after posting and it didn't make a difference...
1967 SWB c10 sold
1972 Elcamino 496
2012 Denali HD dmax
Old 04-13-2014, 11:42 AM   #7
myyamr7
myyamr7's Avatar
Where the vacuum line goes in, there should be a screw head in the port. it's adjustable, so try some trial and error
Mark
71 C10 Cheyenne
12 Aprilia RSV4
Old 04-13-2014, 05:53 PM   #8
turp mcspray
turp mcspray's Avatar
I would try adjusting the kick down cable. It is simple, free, and does change when it shifts.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
