Old 04-12-2014, 06:05 PM   #1
ChevyJr
Junior Member
ChevyJr's Avatar
Cab rear lip
Does anyone have any experience with fabricating this bend/lip? Oh and dont worry... Thats not my cab corner work. Soon to be replaced. Thanks.
ChevyJr is offline   Reply With Quote
Old 04-13-2014, 12:18 AM   #2
Captainfab
60-66 Nut
Re: Cab rear lip
I don't know if a panel flanger will give enough offset or not. You might check it out. Do you have a H-frame press? If so you could make a fixture to form that.
Old 04-13-2014, 09:44 PM   #3
steveb64
steveb64's Avatar
Re: Cab rear lip
I had to fix that area on both sides of my cab. I used a pair of vise-grips that had 5 inch pieces of steel plate welded to the jaws. I then used this to clamp onto my sheetmetal patch and use it as a bending break. I worked from the top bend down to the bottom bend, used my vise to clamp the tool into as I pushed and hammered the bends. Took my time, adjusted and tweaked each piece as I went, and then did the final cut to fill the hole.
I think they turned out very well.
steveb64 is offline   Reply With Quote
Old 04-21-2014, 11:23 PM   #4
ChevyJr
Junior Member
ChevyJr's Avatar
Re: Cab rear lip
Looks good. I'm going to try my hand at it. If it doesn't work...maybe i'll look for a parts cab and cut that out. Wish me luck!
Old 04-21-2014, 11:38 PM   #5
LT1 Burb
LT1 Burb's Avatar
Re: Cab rear lip
I have a cab I am cutting up with rust free corners and would sell a pair with those pieces.
LT1 Burb is offline   Reply With Quote
Old 04-22-2014, 12:29 AM   #6
ChevyJr
Junior Member
ChevyJr's Avatar
Re: Cab rear lip
Well i have new corners on it. But the flanged lip is what I was looking for. The lip in between the cab corners.
Old 04-22-2014, 12:31 AM   #7
ChevyJr
Junior Member
ChevyJr's Avatar
Re: Cab rear lip
Would you have something like that left on the cab? And maybe part of the driver side firewall? Thanks.
Old 04-22-2014, 02:18 AM   #8
1963chevyc20
1963chevyc20's Avatar
Re: Cab rear lip
Ok! Now that someone has this issue I know I am not the only one!!! But if you look under the cab right were the damage to the lip is done you will see some kind of floor support. It is running parallel with that lip. How do I fix that and is it a floor support?
1963chevyc20 is offline   Reply With Quote
Old 04-22-2014, 09:11 AM   #9
LT1 Burb
LT1 Burb's Avatar
Re: Cab rear lip
SHow me what piece of the firewall.
Old 04-22-2014, 09:38 AM   #10
ChevyJr
Junior Member
ChevyJr's Avatar
Re: Cab rear lip
It gets messy under there. The floor brace is spot welded to the floor, the floor is then spot welded to that lip. In the process of fixing that as we speak. The brace is made of 14 gauge steel which for me isnt the easiest to bend accurately. I've cone close, but not close enough to match what i cut out.
Old 04-22-2014, 11:27 PM   #11
ChevyJr
Junior Member
ChevyJr's Avatar
Re: Cab rear lip
Here is a picture of a firewall and also I was wondering if you have the rear cab brace or rear cab lip. Thanks.
