04-12-2014, 07:39 PM | #1 |
'64 Deluxe Seat
How hard is it to get a hold of a 64 C10 Deluxe seat and what would one be worth?
I don't mind if I have to get it rebuilt and recovered. Did the deluxe seat use the same frame as a standard seat? My truck has had a early 90's F150 seat welded to the original 64 seat frame. It's actually a very comfortable seat but it sits way to high and I'd much rather have a original looking seat than what's in it currently. Attached is a picture of my current seat and then the correct styled deluxe seat. |
04-12-2014, 07:44 PM | #2 |
Re: '64 Deluxe Seat
I just redid my seat from standard to deluxe. My upholsterer was able to add the foam to my standard seat. Mines a 63 though, but I supplied materials and $300 for labor. I ordered the fabric from SMS auto fabrics and got the vinyl locally. I know its a different year, but same process and I hope it helps some.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-12-2014, 09:28 PM | #3 |
Re: '64 Deluxe Seat
The seat frame is different on the custom seat than the standard seat.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
04-12-2014, 09:48 PM | #4 |
Re: '64 Deluxe Seat
we used a factory custom seat cover as a template. they will work on the standard seats if you use the correct height foam in them.
04-14-2014, 08:02 AM | #5 |
Re: '64 Deluxe Seat
how is the custom seat frame different from the standard one?
04-14-2014, 08:15 AM | #6 |
Re: '64 Deluxe Seat
I don't know personally.....but I do know that we used my factory 63 standard bench seat and a factory 63 deluxe seat cover as a template....added the foam and it worked perfectly.....see pic above.
04-14-2014, 12:09 PM | #7 |
Re: '64 Deluxe Seat
Might be something we could do here, have not seen a thread on the different type of seat frames ? do not know what mine was but here is how it looked stripped down to the essentials. 66 GMC
seat back: http://kieth.smugmug.com/Trucks/66-GMC/i-bsmWpL7 seat back cover: http://kieth.smugmug.com/Trucks/66-GMC/i-KbDBhWz seat back: http://kieth.smugmug.com/Trucks/66-GMC/i-gd6Zrz8 seat base stripped: http://kieth.smugmug.com/Trucks/66-GMC/i-2b7Fn8L seat base: http://kieth.smugmug.com/Trucks/66-GMC/i-jSQPW5j seat base curly coil springs: http://kieth.smugmug.com/Trucks/66-GMC/i-fKFGXwN Does anyone know if this is a deluxe seat or a standard seat ? after rebuilding and before covering: http://kieth.smugmug.com/Trucks/66-GMC/i-gbJtqnj |
04-14-2014, 12:24 PM | #8 |
Re: '64 Deluxe Seat
Kieth--that looks like my 61 deluxe seat. the reg one has coil like springs on the bottom. what foam did you use?
1961 chevy K10 my build is------------61K10 build |
04-14-2014, 01:13 PM | #9 |
Re: '64 Deluxe Seat
Heres a few pics of the seat frame on my 63 standard seat and the original seat tag.
04-14-2014, 01:15 PM | #10 |
Re: '64 Deluxe Seat
Keith....Your seat base looks very similar to mine. There are some minor differences, but yours is also a 66 as opposed to my 63.
04-14-2014, 01:37 PM | #11 |
Re: '64 Deluxe Seat
there was a thread about the difference of the seats bases one with 6" of foam and one with coils with padding and burlap etc. my tk came with the custom comfort op.
04-14-2014, 04:40 PM | #12 |
Re: '64 Deluxe Seat
From my understanding you could pick and choose what options you wanted so theres no such thing as a standard custom cab option its all just a mish mash of what the purchaser wanted or could afford at the time. My truck could have been a poverty pack when it left the factory but now its fitted with some very nice options.
Theres definately some good information coming out but I didn't relise how little info there is on the factory correct seats. Theres very few of these trucks in australia so I have pay someone to find me a seat in the US or rebuild one and have it shipped. Although a parts hunting trip back to the US does sound appealing. |
04-14-2014, 09:56 PM | #13 |
Re: '64 Deluxe Seat
I had a custom comfort seat in my GMC. I now have a standard seat that has been reupholstered. the custom seat has less springs and more foam. the standard seat has more springs and almost no foam. this is height wise.
04-14-2014, 09:59 PM | #14 |
Re: '64 Deluxe Seat
forgot to add this is the custom comfort seat and you can see not so much springs and a lot of foam. this seat was a lot more comfortable than the standard seat I have now.
04-15-2014, 09:36 AM | #15 | |
Re: '64 Deluxe Seat
We added 2" of soft foam and 2" of dense foam glued together. When we first tried to install the pre made upholstery it did not fit well, found out that a electric grinder works real well when trying to shape foam rubber, took a lot of material off at the rear corners (rounding and smoothing so the seat back would fold forward . Worked like a champ, but what a mess, little pieces of foam rubber all over the shop. Thought we would never get it all cleaned up. ha ha....... So my 66 GMC has what looks like a 61 Deluxe seat in it. Since it looked original I think it was OEM on my truck (everything else was) good to see the other pictures of different seat construction..... Oh by the by A company here in Tulsa has most of the Springs in Stock for older vehicles, I bought mine at American Trim and Upholstery supply, 918-834-6691 Last edited by kieth; 04-15-2014 at 09:48 AM. |
04-15-2014, 11:47 AM | #16 |
Re: '64 Deluxe Seat
Kieth---thanks for the info
04-15-2014, 08:30 PM | #17 |
Re: '64 Deluxe Seat
i recently bought a 66 project. Previous owner took bench seat out. I'm looking to go back to the bench. Any ideas as the best places to pick one up other than ebay?
04-15-2014, 08:34 PM | #18 |
Re: '64 Deluxe Seat
check out your local pick and pulls and your local craigslist. theres a few 60-66 parts vendors in colorado...should be pretty easy to source one.
