Old 04-12-2014, 09:54 PM   #1
62 Barnfind
62 Barnfind's Avatar
Turn signal cable
I am in need of a new turn signal cable mine is bent and rusted. I found one at classic industries and ordered it and when it came in it's to short. It says it is for a impala and a 62 truck. Did anyone else have this problem? Does anybody know where to find the right cable?
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 04-13-2014, 08:26 AM   #2
PGSigns
PGSigns's Avatar
Re: Turn signal cable
Lost me on this one. What is a turn signal cable? All mine are wires.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-13-2014, 10:05 AM   #3
62 Barnfind
The cable runs from the turn signal assembly to the switch. I ordered a new one and it's to short. Did anybody on this site ever replace it and where did you buy the correct one? I can use the short one but I will have to remove the colum and re drill the switch mounting holes.
John Z
62 Barnfind
Old 04-13-2014, 11:25 AM   #4
3 On Da Tree
Only cable I have seen used on a Chevy is for an Impala.
There are some on Ebay
3 On Da Tree is offline   Reply With Quote
Old 04-13-2014, 12:16 PM   #5
Greg63
Enjoy your truck
Greg63's Avatar
I have never seen such a thing.
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 04-13-2014, 12:37 PM   #6
BADAZ chevy guy
BADAZ chevy guy's Avatar
Where is the switch mounted that you need a cable to operate it? AND, why don't you relocate it?
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline   Reply With Quote
Old 04-13-2014, 12:41 PM   #7
Bullett
I have never seen this either. As far as I can see, my 62' doesn't have this either. Could someone have put an Impala set-up in your truck?
Bullett is offline   Reply With Quote
Old 04-13-2014, 01:04 PM   #8
jtrichard
some if not all of the 60/61 and 62s used the cable with the switch down on the column http://img.inkfrog.com/click_enlarge...&aid=306971192 and http://www.ebay.com/itm/60-61-62-Che...1fb8b1&vxp=mtr
jtrichard is offline   Reply With Quote
Old 04-13-2014, 01:06 PM   #9
BADAZ chevy guy
WOW! I guess I wasn't to old to learn something new. lol
Old 04-13-2014, 04:17 PM   #10
62 Barnfind
I have the new Impala cable but it's to short. The truck cable is about 1in longer so the mounting screws are off from the new one. I can relocate but I didn't want to drop the column just for this switch. I can't get my right angle drill to get into the right location. I guess I need to drop it because I am also having a problem with the horn also. There was a member on here that rebuilds columns. Does anybody remember?
John Z
62 Barnfind
Old 04-13-2014, 06:32 PM   #11
HumphreyMurdoch
HumphreyMurdoch's Avatar
I don't know about the differences, but someone has drilled new holes in my column in the past from the cable being too short. It was probably from it breaking and instead of replacing they just bent the end and made new holes. I believe that's called ingenuity. haha!
HumphreyMurdoch is offline   Reply With Quote
Old 04-13-2014, 06:47 PM   #12
markeb01
Senior Enthusiast
markeb01's Avatar
Wow I've learned something new as well. I replaced my original 1960 column 20 years ago, but I don't remember it having anything like that.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-13-2014, 08:28 PM   #13
PGSigns
PGSigns's Avatar
I was a new one on me too. I have had a 63, a 64, and now a 65 and a 66 but no 60 or 61's.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 04-13-2014, 09:15 PM   #14
HumphreyMurdoch
Just one of the many reasons these 60-62's are so zany! Look at us over here with our hydraulic clutches, torsion bar suspension, nutty cable operated turn signal and bonus x-member frame rails. We're out of control!
Old 04-13-2014, 10:01 PM   #15
DPowers
DPowers's Avatar
TruckandCar Shop maybe?
http://www.truckandcarshop.com/index.html
DPowers is offline   Reply With Quote
Old 04-13-2014, 10:58 PM   #16
Softpatch
Softpatch's Avatar
Never seen this
and would upgrade to 63-72 turn switch with wires
if this is not a high end factory correct restore truck
Softpatch is offline   Reply With Quote
Old 04-13-2014, 11:13 PM   #17
sigshooter
sigshooter's Avatar
I have one I am pretty sure, it is on a column in my shed. I have about 6 auto columns in there and I remember that unusual set up on a couple of my columns... I will look first chance I get and get back with ya
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 04-14-2014, 06:10 AM   #18
62 Barnfind
Thanks for checking. Softpatch I was wondering if I could switch it to a 63 or newer set up? It would be easier to deal with than this setup.
John Z
62 Barnfind
Old 04-14-2014, 07:57 AM   #19
sigshooter
sigshooter's Avatar
As far as switching them over..... I know the plug ins are different, I did put an older column in a 65 once. I cut the plug ins off and rewired it, so it can be done.
1966 Short stepside
1964 long bed
Old 04-14-2014, 12:31 PM   #20
61K10
61K10's Avatar
my 61 had that set-up. I know i saved it, but where is it? will look for it. post up some measurements.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 04-19-2014, 09:28 PM   #21
62 Barnfind
Ok I finally got the turn signal to work. I lowered the column and repositioned and mounted the switch. I cut the cable sleeve and installed the turn signal cable. Now if I can get the horn to work I can get it on the road. Here are some pics.
John Z
62 Barnfind
Old 11-16-2017, 07:53 PM   #22
rebeason
My turn signal cable pulled loose, how does the cable connect to the switch? I see the switch portion that moves but can not see how to connect the cable.
rebeason is offline   Reply With Quote
Old 11-16-2017, 09:54 PM   #23
DPowers
DPowers's Avatar
Small pin on the switch that the cable end slides over and is held by a clip.
Old 11-20-2017, 09:05 PM   #24
rebeason
I'm guessing my cable has been broken off on the end, it is just a plain straight cable, nothing to hook on to. Looks like I need a new cable if I understand.
Old 11-21-2017, 11:24 AM   #25
bpmcgee
bpmcgee's Avatar
The lower end doesn't have a loop or anything. It's a straight cable that is grabbed by the switch mechanism using a spring-loaded clip.
B
bpmcgee is offline   Reply With Quote
