Old 04-13-2014, 10:50 AM   #1
dyno
dyno's Avatar
'58 Front fender brace or not?
I've repaired both front fenders on my 58 GMC and was getting ready to weld the fender brace tabs back on. Are the braces really necessary?
"Built- not bought"
1958 GMC 150 4x4 in progress
1980 K20- Restored
1985 K3500 Flatbed
58 GMC 4x4 build thread:
http://http://67-72chevytrucks.com/vboard/showthread.php?t=557675
dyno is offline   Reply With Quote
Old 04-13-2014, 11:15 AM   #2
55dude
55dude's Avatar
Re: '58 Front fender brace or not?
yes!
55dude is offline   Reply With Quote
Old 04-13-2014, 12:44 PM   #3
_Ogre
_Ogre's Avatar
i don't run any, only a few would fit on a lowered truck any way
with a totally boxed frame i would have to make brackets for each one or modify them to fit
shop air compressor timer
Old 04-13-2014, 03:28 PM   #4
mr48chev
mr48chev's Avatar
I've had fenders on AD trucks crack when I didn't run the braces but don't know about TF trucks having or not having that problem. My rear fenders flexed just enough to have the left one crack at about 2 oclock on the wheel well as you look at it from the side. I figure it was that little bit of vibration I got running down the road on the roads around here.
My ongoing truck projects:
Old 04-13-2014, 03:59 PM   #5
Speedbumpauto
Speedbumpauto's Avatar
I use one on the rear of the rear fender where it's not supported very well, mostly because I saw it vibrate some while towing it even on a trailer...but the trailer was rough riding. Don't use any on the front and don't see the need since they are well supported. caveat; I'm not going to drive with any load on any dirt road at any speed and they would probably get in the way of my ride height.
Speedbumpauto is offline   Reply With Quote
Old 04-13-2014, 05:06 PM   #6
OrrieG
OrrieG's Avatar
Kept mine to much flexing off road.
OrrieG is offline   Reply With Quote
Old 04-13-2014, 10:32 PM   #7
dyno
dyno's Avatar
Done...welded them back on. Thanks for the input.
I've been making great progress on the truck over the winter. Entire chassis and drivetrain are all done, all patch panels and rust repair also. I'm sending everything out for sandblasting this week and then I'll shoot everything with epoxy primer.
I really need to post some pics on my build thread. I sure wish I could post directly from my PC instead of using Photobucket!
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 04-13-2014, 11:15 PM   #8
Kim57
Kim57's Avatar
You can.
When you're making a post scroll down and there is a manage attachments button. When you click it a new window will pop up that has a browse button that lets you select pics from your P.C.
That's how I do all my pics.
You can do up to five just by using the button after each one you upload.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 04-13-2014, 11:39 PM   #9
dyno
dyno's Avatar
Thanks Kim! I'm a real dip when it comes to computers.
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 04-14-2014, 09:37 AM   #10
dyno
dyno's Avatar
That was alot easier than Photobucket. Thanks Kim.
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 04-14-2014, 05:56 PM   #11
Kim57
Kim57's Avatar
Glad that worked out for you.
Truck looks good.
Kim
My build thread
