Old 04-13-2014, 12:48 PM   #1
squidley63
RPM on the highway
I want to get an idea on what rpm that others are seeing on the highway without overdrive as I'm pretty sure my tach is off or something as the rpm seems to be lower than indicated at anything above idle. I have a small block in it with msd6al ignition with vdo tach and have been stuck between their tech departments on if I have an issue. Msd thinks I need a tach adapter, but vdo says my tach will work fine with an mad box. Neither will tell me what the symptoms are of needing an adapter and not having one.
My rpms indicated at 55 mph is almost 3500 rpm with the stock 3 speed and 4.11 gears with 235 75 15 tires. Calculators are telling me I should see about that rpm at 65 mph. I know our trucks arent very aerodynamic but I think it shouldnt cause this much difference from calculated.
I have checked the simple stuff like slipping clutch and any bad connections between the tach and the mad box and the dip switch setting on the back of the tach. Any info others could give me would be greatly appreciated.
squidley63 is offline   Reply With Quote
Old 04-13-2014, 04:37 PM   #2
64tantruck
64tantruck's Avatar
Re: RPM on the highway
I'm running about 2800 rpm at 55-60mph I'm running a 3:73 gear with TH-350 tranny. and 16 inch wheels on my C-20 I'm running a 350 engine with a Holley 750 on it for a carb.
glenn
Glenn Korec
Jamesville NY
64 C20 350ci Turbo 350 tranny 3.73 gear with air ride.
61 Apache10 (wife's truck) 327ci powerglide.
http://67-72chevytrucks.com/vboard/s...d.php?t=570100
64tantruck is offline   Reply With Quote
Old 04-13-2014, 08:09 PM   #3
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: RPM on the highway
Formula To Determine Rpm Final Drive Gear Ratio Tire Size And Mph
Gear Math
MPH = (RPM X Tire Diameter) ÷ (Gear Ratio X 336)
Example:
MPH = (3,000 X 26) ÷ (4.10 X 336)
MPH = 78,000 ÷ 1,377.6
MPH = 56.6
RPM = MPH X Gear Ratio X 336 ÷ Tire Diameter
Example:
RPM = 70 X 4.10 X 336 ÷ 26
RPM = 3,709
Gear Ratio = (RPM X Tire Diameter) ÷ (MPH X 336)
Example:
Gear Ratio = (3,000 X 26) ÷ (70 X 336)
Gear Ratio = 78,000 ÷ 23,520
Gear Ratio = 3.31:1
Tire Diameter =MPH X Gear Ratio X 336 ÷ RPM
Example:
Tire Diameter = 65 X 3.31 X 336 ÷ 2,700
Tire Diameter = 26.8 inches
Effective Gear Ratio = (Old Tire Diameter ÷ New Tire Diameter) X Gear Ratio
Example:
Effective Gear Ratio = (26 ÷ 28) X 3.55
Effective Gear Ratio = 3.29:1
http://www.carcraft.com/techarticles...e_and_mph.html
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 04-13-2014, 08:20 PM   #4
BADAZ chevy guy
BADAZ chevy guy's Avatar
Gear Math
Example:
MPH = 56.6
Example:
RPM = 3,709
Example:
Gear Ratio = 3.31:1
Example:
Example:
I couldn't have said it better my self.
Now my brain hurts. lol
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline   Reply With Quote
Old 04-14-2014, 08:17 AM   #5
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
squidley, how did you verify your mph?
Larry
fleetsidelarry is offline   Reply With Quote
Old 04-14-2014, 09:03 AM   #6
kieth
kieth's Avatar
measure the diameter (height from ground to top of tire or the rear)
take a look here......you will be able to see your speed @ different rpms...
TORQUETOGROUND_Master_r.pdf
kieth is offline   Reply With Quote
Old 04-14-2014, 09:39 AM   #7
cArNaGe
This is easier...... And it's fairly accurate. I'm @ 3000 rpms on level highway doing 60. TH350 with 3.73 gears and 275/50/15 tires.
https://itunes.apple.com/us/app/spee...557871911?mt=8
or
https://play.google.com/store/apps/d....android.tacho
or
use a GPS if you have one. My 10 year old cheap GPS has a speedometer in it.
cArNaGe is offline   Reply With Quote
Old 04-14-2014, 10:12 AM   #8
siggyfreud
siggyfreud's Avatar
My guess would be that your RPM is right, and your speed is wrong. Have you verified your speed?
siggyfreud is offline   Reply With Quote
Old 04-14-2014, 05:35 PM   #9
squidley63
Speed verified with GPS on phone. I did finally get in touch with someone at vdo that had me verify the potentiometer setting on the back of the tach(it should be centered). Mine was off bad and while I was there I pushed the dip switches back and forth to ensure they were fully switched. Lo and behold my rpm indicated dropped almost to what they should be according to the gear calculators.
I'm amazed at how seeing the number on the tach has influenced how I drove the truck. Just seeing the lower number has made a world of difference in how it feels to rundown the highway. The mind does some strange things to us sometimes i guess.
