Dude...I'm a CHICK
Tapping sound???
On the passenger side, I hear a tapping sound, the faster I go, the faster the tapping sound. I took off the valve cover, as far as I can tell, no bent rods, no cracked valves. What else should I look for while I have it apart? Could it be an exhaust manifold leak?
Open for suggestions. Thanks yall!! junk
~*~*~*~*~*~*~*~*~*~*~*~*~* "The unexamined life is not worth living" -Socrates ~*~*~*~*~*~*~*~*~*~*~*~*~* '71 GMC Suburban 4x4 |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Tapping sound???
Check the converter to flexplate bolts...Also may be an exhaust leak.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
If you rule out an exhaust leak maybe try this. With the engine OFF, wiggle the rocker arms to check for excessive clearances. If you find an obvious loose one, it could be as simple as tightening the rocker arm nut maybe 1/8th turn. Start the engine and see if the tapping is quieter. It could be as simple as adjusting the rocker clearance(s).
A not so simple fix would be if you have a collapsed lifter on a cylinder, or a wiped cam lobe. Try wiggling the rockers first. Good luck! POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
you say "the faster I go" does that mean it only does it while moving or does it still do it when stopped with the hood up...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
