Getting wires into the doors in an AD
For those of you who are so inclined, how are you getting wires into the doors of your AD trucks? I'm not doing power windows but I do want keyless entry power locks, so I'm looking at how best to run the wires into the doors for that.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
![]() Join Date: Jul 2007
Re: Getting wires into the doors in an AD
Some of the vendors sell flexi tube kind of things to run the wires through but I haven't looked at them for so long that I totally forget who has them.
There are some ideas here. http://www.4wheelparts.com/Doors-Doo...03&t_pt=101260 I see that Summit has some with the stainless braided conduit for about 40.00 ![]()
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 04-13-2014 at 08:50 PM. |
hit the wrecking yard and look how the new trucks and see how they are done for some ideas.
Mine are TF but should work the same. Came with my window kit but I think they're available separately. Its a coil spring, kind of like a screen door spring but larger. It has two plastic/nylon/abs type bushings that fit, one in the door and one in the jam where it holds the spring, and the spring slides in and out of the door bushing, bending slightly, when the door opens and closes. Wires are inside. It doesn't make noise and it works slick.
#5 | |
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
![]() Join Date: Dec 2012
Specialty power windows makes the spring based kit mentioned above I have used it on several Works great
1946 car hauler 1948 surburban 1937 chevy sedan 1940 olds sedan (project) 1967 ss396 chevelle 1999 dually crewcab(24000 miles) |
here is pic of kit
try again
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
What about the plastic plates used on the rear barn doors of some of the SUV's. They screw to the body and to the door and the metal contact plates touch when the door is closed, nothing in the door will work if door is open though, won't matter if it's just for power locks, I'll find a pic for you.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
Something like this. This way, door jambs are clean, no wires to break, etc...
#11 | |
the springs work marginally on a task force, not sure how they'd work on a ad truck
problem i ran into was size, they only hold 4 small wires. i needed room for door solenoids, speakers and power windows all big wires i made these: ![]() ![]() ![]() i drew it up in autocad to get the pivots right. all material came from home depot ![]() more pics in my build ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#13 |
I don't know, Ogre, better brush up on your packing skills. I would have liked the spring to be a little bigger but I got all those wires in there.
#14 |
#15 |
56 - autocross
painless has a door jam tac kit. I am sure if you need more wires, look at newer car.
#16 |
That one is from a sliding door for a minivan, there are several different variations but offer the cleanest solution I believe.
#17 |
Some very fine ideas on this thread,but this one shows some supreme ingenuity.Has anyone put this to use?Are there variants out there that would allow more than 2 contacts?( i guess power could be brought into the door this way and split within the door itself).And I'm trying to anticipate what disadvantages there would be to not be able to use something while the doors are open?
#18 | |
I personally don't like these, but they work well on millions of mini vans! So I guess they work. When I had power windows in my AD I simply ran them tied to the hinge. It was a shrink wrapped pair of wires, very thin, tied to the hinge with nylon ties. On the cowl side there was a big loop so as to be sure there was enough room and it worked like a charm for years (until I sold that cab). That's how I did it as I remember, it was a piece of cake. Brian
#19 |
[ When I had power windows in my AD I simply ran them tied to the hinge. It was a shrink wrapped pair of wires, very thin, tied to the hinge with nylon ties. On the cowl side there was a big loop so as to be sure there was enough room and it worked like a charm for years (until I sold that cab).
That's how I did it as I remember, it was a piece of cake. Brian[/QUOTE] THAT is what I do with my AD's, they have been on there for 15 years like that 0n my 55
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#20 |
![]() Join Date: Jan 2009
There's prettier ways to do it, but very functional. Astro van or Aerostar, I can't remember. Only issue, I had to shorten the spring loaded contacts because of th angle the door opens.
1949/1954 with LS swap-yeah! http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos |
