April Special: 14" Front & Rear Brake kit - $1,695
C10 14" Front & Rear Big Brake System - $1,695
Now that we have officially finished our front and rear 14" brake kits, made by Baer, it is time to run a special. We keep the pricing really low to begin with on these kits, but we are offering some savings this month on the front and rear kits together. Below is a few key points about our 14" brake system. We have finally gotten to a point, where we have these kits on the shelf and ready to ship. Some pictures below show the kit installed on a stock spindle (not included). No need to change spindles, and will work with almost all aftermarket drop spindles. (McGaughys, ECE, BellTech, Western Chassis, CPP - non-modular). Complete instructions included for both front and rear. Features & Benefits • Available in 5-lug or 6-lug • Front Corvette C5 Caliper (Brand New w/ Pads) • Rear Mustang caliper with integrated parking brake (Brand New w/ Pads) • NO machining required to install rear kit • Machined aluminum hubs w/ Timken or SKF bearings (Pre-installed) • Works with any stock spindle or stock style drop spindle. Requires mods to mount caliper. • 14" cross drilled, slotted, zinc plated and directional vented rotor all around • Lifetime warranty against rotor warping (does not include normal wear and tear) Additional Add-Ons: Front and Rear DOT SS Hoses: $195 Disc Brake Master Cylinder: $100 E-Brake Cables: $125 ![]() ![]() |
Prestige Worldwide
![]() Join Date: Feb 2001
Re: April Special: 14" Front & Rear Brake kit - $1,695
Hey Travis, do you have any fitment templates and also what is the minimum diameter wheel required, I assume 18"?
I should have that shortly for you. It will clear in most 18's, but once I have that template, it will best to double check.... it will be tight, depending on the drop center of the wheel. The image above is shown with a 20" wheel.
![]() Join Date: May 2013
Will this widen the track at all?
67 SWB LS2/4l70e... http://67-72chevytrucks.com/vboard/s...d.php?t=587435 |
Just wanted to post up a link to the brake template, if any are wanting to measure to fit 18" wheels.
http://www.azproperformance.com/manuals/C078P.pdf |
Ttt
We started this April special a little late, and have decided to extend a few weeks into May.
