Old 04-13-2014, 07:41 PM   #1
of13swc
Fuel Line question
So I relocated my fuel tank to the rear of the truck. My question is what to use for a longer fuel line? I bought one from a the years that had a rear fuel tank, but that was a no go. Is there a pre bent fuel line somewhere? I have rubber line currently but do not feel real safe with that and I have tried to bend the line my self numerous times and whoops my butt every time. Any suggestions would be greatly appreciated.
of13swc is offline   Reply With Quote
Old 04-13-2014, 07:57 PM   #2
BigSix
Re: Fuel Line question
If I am not mistaken LMC has some fuel line options? If you're having trouble bending line you buy at parts stores, you're not alone. Try getting some cupro line - its copper/nickel/iron. These lines are ultra rust resistant and bend/flare real easily - I am not positive but I believe they are sold for use as fuel line as well.
BigSix is offline   Reply With Quote
Old 04-13-2014, 08:43 PM   #3
PGSigns
PGSigns's Avatar
I just got 3/8" steel line and the fittings from the parts store and bent all new line from front to back. I have good benders so it was easy. A cheap bender will work and make a good looking setup.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-13-2014, 10:15 PM   #4
siggyfreud
siggyfreud's Avatar
If money isn't an issue you could run 20' of braided AN line.
siggyfreud is offline   Reply With Quote
Old 04-14-2014, 03:05 PM   #5
RAYDAY
RAYDAY's Avatar
I use coil of steel line and a decent bender like anything it take time and patiance to be good at. That copper/buckle line work nice 25 ft of it is $75-100 if I remember right so better take ur time make it nice don't kink it! Lol
96 s10 static drop smooth and blue
99 silverado nothing stock layed out on 24s
65 c10 bagged patina driver
http://www.myrideisme.com/Garage/az480
half-assed build thread
http://67-72chevytrucks.com/vboard/s...=1#post5206828
RAYDAY is offline   Reply With Quote
Old 04-14-2014, 03:37 PM   #6
badboy
u can buy a role of aluminum fuel line 25 foot dirt cheap from summit or jegs
5/16 or 3/8 easy to work with when installing
badboy is offline   Reply With Quote
