04-13-2014, 06:44 PM | #1 |
LS ENGINE SWAP
I have a 84 GMC C1500, need some help. Im stuck between rebuilding the sbc 350 in it with aluminum heads, cam, intake, new carb and lots of machine work, or doing a LS swap? Trying to stay in a decent budget, but run good amount of hp with decent gas mileage. I've read LS's putting 600hp with 20mpg which is great for me, only looking to run around 425-450hp for a every day truck back and fourth to high school. What should I do? Thanks!
04-13-2014, 07:48 PM | #2 | |
Re: Need advice: LS ENGINE SWAP
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
04-13-2014, 09:05 PM | #3 |
Where is a good place to get one? My buddy was telling me get one from a junkyard. Do you know what a LS1 would run with a wiring harness etc? And also do the motors bolt right up to the tranny or get a transmission with the motor also? Just trying to figure out what I am going to do. Thank you for your response!
04-13-2014, 10:03 PM | #4 |
Re: LS ENGINE SWAP
That's what I have been trying to figure out, how do you start a new thread so I don't comment on somebody's else's? Thanks!
04-13-2014, 10:16 PM | #5 |
Re: LS ENGINE SWAP
Look at my build man, I'm a novice to all this, but mines going to be cruising soon
04-14-2014, 02:11 AM | #6 | |
meowMEOWmeowMEOW
Re: LS ENGINE SWAP
You really should take a look at the builds section up top, and the FAQ in the stickies. There are a number of builds that are very detailed from start to finish, with pictures, part numbers etc. The FAQ should have links to the solutions to common things like Fuel Systems, parts lists and costs etc. There is a huuuuuge amount of information in those areas, which should get you everything you need to decide if its right for you. It will cost more than a sbc swap, but a stock ls truck motor comes in around 305 (or more, depending which one you get). It does so easily, and more efficiently than a mild-built sbc. Since I heard the words "high school", I'll pose another figure. If you plan on keeping the truck as both a fun car and a daily, the LS motor is the way to go if you can afford it (make sure you can actually afford it, NOT just scrape together the minimum for a junkyard swap, or your project won't ever get done). Between the extra mpg, the tame street manners and the ease of starting in any weather, its much much much easier to swing as a daily than a carbed sbc. The first time its 40* and rainy, and the sbc is running too rich or is stuck on high idle....you'll WISH you went LS.
