Old 07-28-2003, 04:04 PM   #1
68_c10_on20s
68_c10_on20s's Avatar
casting numbers on a small block
can some one help me decode these casting numbers the first set is 13r482884,second set is t0703ckj i know its a small block but thats about all i know
93 Fleet Budget Build http://s150.photobucket.com/albums/s...zted71/hoopty/
68_c10_on20s is offline   Reply With Quote
Old 07-28-2003, 04:06 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
MORTEC.COM
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 07-28-2003, 04:20 PM   #3
68_c10_on20s
numbers
tried it couldnt find it there
Old 07-28-2003, 06:00 PM   #4
72c10step
WHYBYNU when old will do?
72c10step's Avatar
Here's what I found at http://www.nastyz28.com/sbchevy/sblock.html
13R482884
This is the Partial VIN Code ID. 1 Stands for Chevrolet, 3 is for 1973, R is where the original vehicle was produced, in this case Arlington. The last 6 numbers are from the original vehicle's VIN#.
T0703CKJ
T is where the engine itself was cast, this was was at the Tonawanda plant. 0703 is the casting date, July 3rd. CKJ is the option code for this engine, which states that it is a 1973 350 4 bolt main that originally came with a turbohydramatic trans, and was installed in any of the following vehicles (under comments section and a little vague, so bear with me if I'm wrong) A B and F bodies, Bel Airs, and Kingswd?? (not sure on this last one).
Hope this helps!
-72 Chevy C10 Stepside
-2002 Chevy Silverado 2500HD 4x4
-1984 Jeep CJ7
-1995 Polaris XCR600 Custom
-2003 Honda 300ex
72c10step is offline   Reply With Quote
Old 07-29-2003, 05:03 AM   #5
OhioDan
OhioDan's Avatar
Check here.----->http://www.mortec.com/location.htm
That should help you out?
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 07-29-2003, 08:05 AM   #6
JimKshortstep4x4
Smile
The numbers that 68 c10 listed are not casting numbers. They are off the front pad of the engine and are stamped numbers.
Mortec lists casting numbers, the site listed by 72c10 is the site to go to for the stamped pad numbers.
Jim
