71' LWB Chevy. Transferred the gas tank from cab to frame.
I have a blazer tank I'm using in the swap but have run into trouble with the height of the tank. It is above the frame rail and to remedy the problem I'll either need to lower the tank 3" or notch out the bed frame channel. Anyone been here before? Can't really afford to ditch what I have to buy the proper kit unless I can find a buyer for a plastic blazer tank from that era. If the tank is only 12" inches off the ground will that pose any issues or concerns?
![]() Join Date: Nov 2001
Re: 71' LWB Chevy. Transferred the gas tank from cab to frame.
What year blazer tank? 69-72 or 73+ ?
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red |
I'll check the receipt when I get home but I think 67-72. From the chevy supplier in Arkansas.
![]() Join Date: Jan 2012
I have seen it done both ways, personally, I would go with sectioning the bed rail. If you section it and weld in some replacement sheet metal, you should be good to go. I believe that the higher you get the gas tank off the ground the lower you can go with the suspension itself.
Here is a link to one of those TV car shows and it shows them sectioning the bed. http://www.powerblocktv.com/episodes...ls-engine-swap
Matt Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655 "Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!" |
