Old 04-14-2014, 11:30 AM   #1
biohazardbill
PB Narrowed arms and 22s
If you are running this setup what backspacing/tire size are you running and what issues have you ran into?
I had the regular arms and 20s but have since switched to the narrower arms so I need to order some new wheels.
biohazardbill is offline   Reply With Quote
Old 04-14-2014, 12:01 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: PB Narrowed arms and 22s
I guess I'm kinda stumped with your question.
If you were going to switch wheels,... why did you switch a-arms?
You could have got "whatever backspace you wanted" to work with the standard width Porterbuilt arms.
We need a little more info:
What year truck?
Stock crossmember?
Extreme Dropmember?
Touring Dropmember?
Mild Dropmember?
Is it even bagged?
Static dropped?
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 04-14-2014, 12:11 PM   #3
biohazardbill
Extreme dropmember, truck lays frame. I think... I bought it a few years ago. Round tube, not square.
I didnt plan on switching the wheels. When I originally bought the a-arms they were only available in the standard width (same time i bought the crossmember). At that time people were using 20s on the front when laid out.
I have since used the A-arms on a different project and when I went to order replacement arms I had the option of 1" narrower to run 22s, hence why I now want to swap the wheel size to match the rear.
Truck is a 65 Suburban
Bagged, lays frame
As far as backspacing I dont think I can get whatever I want. I have Coy wheels right now and my first experience with them was not the greatest. So anything custom from them i believe would be out of the question.
Old 04-14-2014, 12:16 PM   #4
biohazardbill
Looking at Coys site right now I may have to go with a different option....
Apparently they dont offer black C5 anymore
Old 04-14-2014, 12:29 PM   #5
biohazardbill
Now im confused... found them on the site through a google search... I am going to have to call them
Old 04-14-2014, 12:32 PM   #6
lolife99
lolife99's Avatar
If you're going to run the 22x9 up front,... I would go with the most BS that Coys offers.
That appears to be 5.5" bs.
That should work with a 1" narrowed a-arm,... but I'm not as familiar with these 60-66 trucks.
Keith
Old 04-15-2014, 01:37 AM   #7
64shortc10
64shortc10's Avatar
I have PB narrowed arms, dropmember and 22's!
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 04-15-2014, 01:48 AM   #8
64shortc10
64shortc10's Avatar
22x9.5 with 5.5 backspace wheel is tucked but still a little close to the fender for low turning! Run a 265-35-22 or smaller tire! I have a 265-40-22 and it's too big touches the firewall but I'm also bodydropped 3/4 inch!
Tony from Norcal
Old 04-15-2014, 08:16 AM   #9
biohazardbill
Thanks Tony.... Mine will only be 9" wide wheels so they will tuck farther in. I cant remember the size tires I have in the rear. I will check this weekend but I plan on getting the same size. Still have not found another grill lol.
