Old 04-14-2014, 08:00 PM   #1
Flthead
Rear gear set ?
I have a '64 8ft fleet 292 3 speed overdrive . Looking to change rear gears from 3.73 to a 3.42. Looking for 3 series carrier
Flthead is offline   Reply With Quote
Old 04-14-2014, 11:43 PM   #2
Captainfab
60-66 Nut
Re: Rear gear set ?
You do realize that you will have to change the carrier also when changing from 3.73's to 3.42's?
There are many sources for differential gears.
http://www.summitracing.com
http://www.ring-pinion.com
http://www.drivetrainspecialists.com
Old 04-15-2014, 02:42 AM   #3
Flthead
Re: Rear gear set ?
Ya I'm finding this out. What's a lower gear set without changing carrier
Old 04-15-2014, 09:08 AM   #4
kieth
kieth's Avatar
Re: Rear gear set ?
What are you trying to accomplish ?
kieth is offline   Reply With Quote
Old 04-15-2014, 09:16 AM   #5
LT1 Burb
LT1 Burb's Avatar
Re: Rear gear set ?
I may have a carrier. I took it out of a pickup but don't know what it was.
LT1 Burb is offline   Reply With Quote
Old 04-15-2014, 09:39 AM   #6
Flthead
Re: Rear gear set ?
I have 2 trucks same setup , 3 speed overdrives 3.73 rear gears. I want better highway top end. '70 I have sucks on highway or at least like a little better. 235/75-15 tires
Old 04-15-2014, 10:49 AM   #7
Captainfab
60-66 Nut
Re: Rear gear set ?
The 3.73's are the highest gear that will work on a 4 sreies carrier. The next step up is the 3.42 gear which you will need a 3 series carrier for.
Old 04-15-2014, 02:09 PM   #8
LVPhotos
LVPhotos's Avatar
Re: Rear gear set ?
The drop is about 200-300 rpm. Chart
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 04-15-2014, 05:03 PM   #9
kieth
kieth's Avatar
Re: Rear gear set ?
lets check on torque,
3. Engine ?
2. tire diameter from ground to top of tire
3. transmission final drive
we know your rear axle ratio I will run a custom spreadsheet for you and besides looking at speed and rpm we will also look at how much torque you have now and how much torque you will have with the changes....you want to make......before you make them......Kieth
