04-15-2014, 12:31 PM | #1 |
Curious about linkage
OK, first off, my truck is in the shop, I'm just trying to get an idea of what they're going to face...
My '71 currently has a TH350 with a B&M floor shifter, and we're swapping in the LS1/4L60 out of my '98 Trans Am. I'm just wondering if anyone else has done the TH350 to 4L60 swap, what kind of linkage modifications are needed for the shifter? Should there be any issues, or should I just be looking for a new shifter assembly? |
04-15-2014, 03:48 PM | #2 |
Re: Curious about linkage
I used the stock linkage took ghe c cup off my th350 and bolted it too the 460le
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
04-15-2014, 03:54 PM | #3 |
how does that shifter behave or work with the 4 speed vs the original 3 speed?
Like David said I also just used my original linkage from my TH 400 and used my standard column shifter but that may not be the case with an aftermarket shifter?
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
