04-15-2014, 04:37 PM | #1 |
Ignition grounding problems
I am having trouble getting my '70 to engage the starter. When I turn they key I get nothing unless I go through the gears from Park to 1st gear. After that it starts just fine. What on earth is causing this? It is very annoying. How is the ground connected through the column shifter?
Another separate problem I'm having is that the shift rod under the hood is constantly becoming disconnected (over behind the brake booster). It usually pops out when I'm in reverse and then I have to hook it up again. Luckily this has happened at home every time but one day it's gonna pop out on me someplace else. Has anyone ever machined a couple of cotter pins to keep this thing from disconnecting? No matter how much I tighten it down, it will pop out again in a week or two. It is a PITA to reach because it requires me to stand on something to reach it properly. |
04-15-2014, 04:41 PM | #2 |
Re: Ignition grounding problems
Your neutral safety switch is out of adjustment. It's the 1/3 round switch mounted on the column, loosen the 2 screws and you can slide it left to right for adjustment, doesn't take much. Test by no start in any gear, starts only in park and neutral
04-15-2014, 04:42 PM | #3 |
I'm guessing your starting issue is a neutral safety switch.
and... As far as the shift rod issue. See if one of the vendors sells the replacement tightening piece and/or shift rod. Might just be worn out.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red |
04-15-2014, 04:46 PM | #4 |
Thanks guys it does look pretty worn. That's why I come here... always dealing with the best!
That also explains why I'm able to start it in any gear. |
