Old 04-15-2014, 04:40 PM   #1
coyotes33
coyotes33's Avatar
Injectors for Turbo.
I currently have a fresh rebuilt stock ls1 with the truck intake and accessories in my 84. I'm planing to throw in a single turbo and about 7 psi. What 48/60# fuel injectors would be a direct fit or very minimal changes to the harness?
coyotes33 is offline   Reply With Quote
Old 04-15-2014, 05:25 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Injectors for Turbo.
Is it actually an LS1, or do you mean just an ls-motor (4.8-6.2?) It depends if you originally installed the Delphi truck-style injectors (stock on the fuel rail with the truck intake), or if you are running the car-style injectors (tall skinny ones with EV plugs on them).
If you have truck injectors, the only real option is Marine 8.1's or go custom. If you switch to the car-style plugs (or already have them), you can pickup something like the F*rd SVO injector/cobra injector, or any 1 of the 100's of custom one's available. The Bosch EV-style plugs are super-common and almost any injector can be made to fit as long as its top and bottom o-ring fitments are correct.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-15-2014, 05:29 PM   #3
coyotes33
coyotes33's Avatar
Its a 5.7 and I did use the stock 5.3 injectors, rail and intake.
Old 04-15-2014, 06:34 PM   #4
wgeyer88
There are plug-and-play for truck motors, gen III anyway.
http://www.deatschwerks.com/products...lverado-sierra
Search Amazon by the part number, you can find them cheaper there.
Will
1970 CST10 SWB LQ4/4L80E
2004 Silverado (sold)
2007.5 Dodge Ram 2500
wgeyer88 is offline   Reply With Quote
Old 04-15-2014, 07:12 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Your setup for the truck style injectors then, like the ones posted in wgeyers post. The 48s or 60s would be fine for what it sounds like you want to do. If you end up looking for the 8.1 injector, make sure its a true MARINE 8.1, not the junkyard pullout 8.1 injector.
If you end up with BIG goals (to the point where you would outpace a 60lb injector), then you'll probably end up switching to car injectors because the amount and variety of vehicles using that style injector means way more options cheaper.
Old 04-15-2014, 09:42 PM   #6
coyotes33
coyotes33's Avatar
Thanks for the link.
Old 04-15-2014, 09:45 PM   #7
coyotes33
coyotes33's Avatar
I wouldn't mind going with the car injectors, I just need to figure out what modifications I need to make on the rails and clips.
Old 04-15-2014, 11:04 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
EV style pigtails, and space the fuel rail up higher (nylon spacers from hardware store work). Super easy, extremely common.
Old 04-15-2014, 11:07 PM   #9
coyotes33
coyotes33's Avatar
Will the pigtails work with the ls7 injectors? I found a few sets over in ls1tech.
Old 04-16-2014, 09:50 AM   #10
Wasted Income
Boosted Member
Wasted Income's Avatar
Just buy a set of the LS1 length (car length) Siemens 60s and be done with it.
Those were enough to support an S400 at 12 psi on a 6.0 on one of my builds, but not so big that they idle like **** on gasoline.
Snip the injector pigtails, solder the "car" style on, which can be snagged from about any port fuel injected GM car (FWD grand prix, lumina, monte, caddys, etc.) and solder them in place, with some shrink tube over your splices. Like an hour of work.
Then you just have to space your fuel rail up. I don't remember the exact distance, but it's out there on the interweb somewhere.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
