Old 04-15-2014, 10:28 PM   #1
RMBLFSH
Drivers Side Cab Vent
1972 Cheyenne Super, Factory A/C truck:
In the drivers side kick panel, there is a door that appears to be operated by a knob that you pull on, to allow outside "fresh" air into the cab.
I can pull the knob, but the door moves very little, and certainly does not appear to open enough to let any air in.
What am I doing wrong, or how does it work?
Thanks,
Rich
RMBLFSH is offline   Reply With Quote
Old 04-16-2014, 12:51 AM   #2
SS Tim
SS Tim's Avatar
Re: Drivers Side Cab Vent
Its the kick panel vent. They are manually operated, pull the knob aft to open. On A/C trucks the right vent is used for outside air introduction during blend operation. If it is sticking/stiff it might be rusty from non-use or there could be a lot of debris down inside blocking it. Either way take a look and lube the moving parts then see what happens. Might have to pull it apart to make it work. If you don't have one it would be a good idea to buy a driver's handbook (owners manual) in addition to the factory service manuals.
SS Tim is offline   Reply With Quote
Old 04-16-2014, 12:23 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
To add to what Tim said, the vent should open 90º.
LockDoc
Leon
Old 04-16-2014, 02:13 PM   #4
RenoKeene
Florida Edition
RenoKeene's Avatar
There are spring loaded detent pins that hold these in, take the pull handle lose and open the vent by hand and you'll see the pin.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 04-16-2014, 06:13 PM   #5
TxTan
TxTan's Avatar
I recently had the same problem. Remove the vent, clean everything, and reinstall where the vent will open from the front of the cab, not from the rear.
72 Chevrolet SWB Super
TxTan is offline   Reply With Quote
Old 04-18-2014, 10:47 PM   #6
RMBLFSH
Thanks all, I followed your instructions, it now works perfectly.
