Old 04-15-2014, 11:20 PM   #1
chritter51
question about wheelbase ? swapping cabs/beds
I am about to start a build on a shop truck.
here is what I have: an 86 single cab long bed & an 86 crew cab long bed dually. I want a half ton 5 lug crew cab. I don't mind putting regular long bed and suspension on dually and having long bed crew 5 lug half ton. but I was wondering if I could put crew cab on my half ton dually and use a short bed?
just wondering. thanks for any input.
chris
chritter51 is offline   Reply With Quote
Old 04-15-2014, 11:22 PM   #2
chritter51
Re: question about wheelbase ? swapping cabs/beds
chris
I meant put crew cab on my half ton long bed and use a regular short bed.
Old 04-16-2014, 04:20 AM   #3
willett
Another Day, Another Dollar
willett's Avatar
Anything is possible but that would Not be easy
Your better to cut down the crew frame, That seems to be what most folks do.
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 04-16-2014, 09:37 AM   #4
J Knight
J Knight's Avatar
If you put the cc on the rclb frame you will have to stretch the frame under the cab then shorten the rear of the frame to fit a short bed. It would be much less work to shorten the dually frame to fit a short bed and swap in the 1/2 ton suspension.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 04-16-2014, 11:09 AM   #5
Jonboy
Slots go on anything!
Sort of. It would be easier to cut the rear of both frames, and use the rear of the frame of the 1/2 ton with the suspension to do the swap you want (since you have it available). You will need to make a plate at the bottom of the frame to match the rail highths, but if you are cutting and welding a frame it should not be too much more of an issue. I shortened the frame on my 3/4 ton and then swapped in 1/2 ton suspension; I wish I had just cut up my donor frame at the same time.
1974 Jimmy- 5.3/4L80e/NP241
Old 04-16-2014, 10:36 PM   #6
chritter51
thanks for the replies. doesn't look like ill be doing any of that. I need to put the truck to work asap so looks like ill have a crew long bed. picking up the dually tomorrow. ill get some pics up on the crew cab pic thread.
chris
Old 04-17-2014, 05:46 AM   #7
andrewmp6
Its easier to take the 1ton crew cab and shorten the frame to a short bed.As far as 5 lug the front is bolt in the rear will take a rear end swap or if its a 14 bolt it could be changed to 5 lug but its not cheap.
andrewmp6 is offline   Reply With Quote
