Old 04-16-2014, 12:25 AM   #1
c10 custom
no spark while cranking but sparks after key turned back
i am having an issue with a 1981 chev truck 3 ton it has no spark
while cranking but when key is released it has spark the pink wire on
the distributor has power when key is in run position but goes out
when cranked and ignition module power wire is the same way could it be the ignition module any help would be great thank you
c10 custom is offline   Reply With Quote
