Old 04-16-2014, 08:03 AM   #1
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Broken Exhaust Manifold Studs
Trick to removing them?
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 04-16-2014, 08:08 AM   #2
cdowns
cdowns's Avatar
Re: Broken Exhaust Manifold Studs
with a torch get it a bright cherry red and then try to grab it with visegrips and turn it out// if there is not enough sticking out to do it that way then i use reverse twist driull bits to drill them out and retapp the holes
Old 04-16-2014, 09:44 AM   #3
BLT gmc
If you can grab it I agree with the heat and twist. I would also try a micro lubricant. Soak it well and keep it wet, the longer you keep it soaked the better. Maybe 2 - 3 days if you have the time. If flush or just short of flush, I use a grade three nut directly over the broken bolt and weld full, cherry hot with a wire welder. If the nut/weld break while trying to loosen,repeat the process. This time just try tightening the nut a couple degrees, sometimes this will break the rust bond better the bolt and the cylinder head. Then just wiggle back and forth. Hopefully each time it gets a little more loose. Finally the whole drill, left handed prefered, tap and possibly heli-coil. Good luck, Bruce
BLT gmc is offline   Reply With Quote
Old 04-16-2014, 11:12 AM   #4
Ironangel
Ironangel's Avatar
Right on, thanks you guys...I did try the heat method and twisted it right off flush! I did manage to drill a 3/16" hole through the broken stud and that thing is stuck tighter than dicks hatband! I'll go ahead and drill & tap a helicoil in it...Thanks for replies and help!
"Two Seventy Two's"
02 3/4 ton Express
Old 04-17-2014, 10:54 AM   #5
slikside
slikside's Avatar
Just to clarify, for future reference. it's not the broken stud that you heat to cherry red, but whatever it is screwed into. In this case, exhaust manifold/cylinder head. Heat expands metal, therefore you heat the metal surrounding the stud, then twist the stud out.
Don't mean to preach, but it sounds like you may have heated the stud itself?
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 04-21-2014, 01:54 AM   #6
Greasey Harley
Greasey Harley's Avatar
Best stuff I ever found for stuck, busted off bolts: rapid tap cutting fluid ( you know, the stuff that's setting beside your drill press). Heat it up with a propane torch and drip rapid tap all over it. Get it f#@&king HOT! Rapid tap won't even smoke or burn. If you look closely, you should see tiny air bubbles coming out of the threads. Let it set for a couple minutes, then just spin it out. Seriously.
I like to use Snap-On baby talon pliers to grab a hold of the busted stud, if its out far enough ( those things are just as amazing). If its flush you'll have to use a left handed drill bit and an extractor.
I'm a boat mechanic, I have extracted A LOT of busted bolts.
Hope this helps, -Russ
Greasey Harley is offline   Reply With Quote
Old 04-21-2014, 04:58 PM   #7
OldCreek
OldCreek's Avatar
I've had some success using "Drill Out" bolt extractor by Alden.
it uses a little momentum/speed as opposed to just a reverse tap….
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
