04-16-2014, 10:20 AM | #1 |
Anyone removed truck rally wheel center section and welded into a wider wheel shell?
Want to buy a 15x12 inch shell: http://www.speedwaymotors.com/15-Inc...-12,31581.html
Remove center section of a stock 6 lug truck rally and weld into new wider shell. Anyone done this? Any input? Thanks |
04-16-2014, 11:21 AM | #2 |
Re: Anyone removed truck rally wheel center section and welded into a wider wheel she
I have done several. I use a ziz wheel on a 4 1/2 inch grinder to remove the center. I have a huge welding lathe at work so I put an axle in the lathe and bolt the wheel to the axle so I can indicate the new rim, tack weld several times before welding.
04-16-2014, 12:50 PM | #3 |
I use the same technique as Mrweld except I normally make 15x10 wheels.
Lateral and radial runout usually indicates less than .007". I believe the production spec is .015". K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
