wiper motor help
yesterday i was going to work, and it was raining, the wipers were working ish...then just stopped working, so i bought a new motor, and its doing the same thing...is there a ground somewhere i need to check? keep in mind i did a LS swap and took out some wires and vacuum lines, but i dont think any of the wires went to motor...they turn on and want to move but dont now
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck ![]() My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
Re: wiper motor help
If they want to move but dont I would suggest looking at the wiper transmission under the cowl to make sure it is not in a bind. Especially if it is doing the same thing with both motors. Just a thought.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint "Cool ain't ever cheap and cheap ain't ever cool" |
There is two motors? I only seen the one
I meant the original motor and the new one.
Oh gotcha...lol I'm like dang I'm a dummy
You might also unhook the wiper transmission for the wiper motor and see if you can move it by hand.
Will do man, thanks, I'd do it now but had some u-joint trouble!! Now running late for work
No problem. Hope it all works out. Thank you for your service to our fine nation.
Don't Crush em Restore em
I had the same problem with a new wiper motor. It was just not strong enough to push the wipers, I took it back and exchanged it for another one, and it has been working fine ever since.
TexasJeff 2009 Silver with Linen Interior Cadillac DTS 1990 Red with White Top and Interior Ford Mustang GT convertible 1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually ![]() ![]() ![]() ![]() ![]() ![]() |
Thanks for the heads up, I'm gonna check all the linkage and if that don't fix it I'll get a new one...this is a remanufactured one
So pretty wierd, I randomly we be to check my wipers and they work good right now, so wierd, haven't done anything to them...they just worked....what the heck???
I had an intermittent windshield wiper motor on my 75 and it turned out to be corrosion on the wiper fuse under the dash. I cleaned off the corrosion and lubed it with a little wd40 and no problems since.
Stock 75 C10 step side. 350 2 BBL, 350 trans. 150K miles. |
#13 |
Holy cow, I'm gonna go check that here soon...hopefully that's it
#14 |
Two ideas:
1) Buy only AC Delco motor from online OEM retailers - should not be that expensive. 2) Before you buy a new motor - check the connector at the motor. Wiggle it while assistant operates the wiper switch. I have a bad connector and was able to patch it back up with electrical tape, but I will get a new connector when my patch finally fails. Those connectors are somewhat fragile after 30+ years of use. If you have a bad connector you can get an OEM AC Delco connector from the same online OEM retailers. Check the online Delco pigtail catalog: www.oewarehouse.com www.oehq.com www.rockauto.com www.autopartstomorrow.com www.gmpartsdirect.com Some have free shipping and usually no sales tax (for now, anyway.) |
#15 | |
I got a new motor already, but I see what your talking about with those connectors, I think that may be one of the issues...I work at orileys and got it pretty cheap, I did keep the old one as a back up
