Old 04-16-2014, 02:48 PM   #1
CHEVY4LLTHEWAY
Rough estimate of how much it will cost to repaint my truck?
So after I graduate high school my dad said that he would get all the body work and get my truck re-painted at a shop. It's a short bed 1987 4x4 with red and black factory two tone, and I want to get it re painted the exact same colors. My question is how much will a shop charge to replace cab corners, rockers, put all new weather stripping and factory trim on, and paint the frame and the undersides of the cab and bed, and paint the truck red and black again? Just trying to get a realistic number in my head to get an idea of how much it'll cost me. Any help would be appreciated.
CHEVY4LLTHEWAY is offline   Reply With Quote
Old 04-16-2014, 02:53 PM   #2
flashed
Re: Rough estimate of how much it will cost to repaint my truck?
Anywhere from 5 to $10,000 depending on where you are and how bad it is .
flashed is offline   Reply With Quote
Old 04-16-2014, 03:47 PM   #3
RandyP
Getting Old; Going Broke
RandyP's Avatar
Everything you listed there you'll be north of 8.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 04-16-2014, 03:54 PM   #4
Keith Seymore
Keith Seymore's Avatar
$3200 for the local shop to shoot my '87 SWB in the original Code 72 Apple Red, in Base coat/clear coat, with me doing all the prep (stripped all the exterior trim and emblems, replaced both cab corners and behind the left rear wheel, fixed numerous dents and dings).
The long version is here: http://67-72chevytrucks.com/vboard/s...d.php?t=342926
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 04-16-2014, 03:58 PM   #5
JWall
Frequent Flyer
JWall's Avatar
I'd say 10+ with the list you've got going there depending on the shop.
Plus depending on who's doing the disassembly since you want frame and under side painted as well.
- Justin
1 Owner 1976 SWB
Old 04-16-2014, 05:34 PM   #6
crashz
crashz's Avatar
I've gotten quotes in those ranges just for full strip and paint with minor body work on my 83. Two tone paint adds to the complexity as well as the major body work.
Frame cleaning and painting does not take a skilled body man though. Its a dirty job that anyone can tackle unless you are thinking show quality. Save some cash here and do it yourself.
You can also do the stripping of the trim, moldings, grill, lights and stuff yourself.
The more you do in your driveway, the cheaper the body work and paint will be.
2012 Chevy 2500HD, 6.0L, 6spd auto, 4x4, ECSB
1987 GMC V3500 Dump, 6.2L diesel, TH400
1983 GMC K2500 - awaiting its restoration and Cummins swap.
crashz is offline   Reply With Quote
Old 04-16-2014, 06:04 PM   #7
Malo83
Cruzzzn' Vet
Malo83's Avatar
Painted my 83 last year, 6 G's for the job, I stripped down the body of everything, went with a solid color, had the roll pan welded in, stake pockets filled, drip rails removed and welded up, new windshield and rubber seal installed as well as the rear window seal replaced
Malo83 is offline   Reply With Quote
Old 04-16-2014, 08:50 PM   #8
cool68
Wow, that is a long laundry list of things to be done. if you wanted a basic paint job, with some body work, could take it to MAACO. but, you will need to find a local shop that works on old trucks/cars and cost will depend on their shop rate, parts needed, etc = expensive.
cool68 is offline   Reply With Quote
