Old 04-16-2014, 04:55 PM   #1
donthekawguy
donthekawguy's Avatar
front shock angle ? and short shock ?
I'm getting ready to tear into the front end of my 66. I'm replacing everything except the control arms. I'm using 2.5 ich spindles and 2.5 inch springs. Will I need to use a shock relocation kit? Also I would like to find a shorter shock for the front. Anyone have a shorter shock part number? The shocks are the last parts I need for the whole swap. The truck should handle a lot better and stop a lot better. I'll post pics during the whole process. Now if it will stop raining I can get started on it.
66 shorty
donthekawguy is offline   Reply With Quote
Old 04-16-2014, 05:21 PM   #2
gofastnut
gofastnut's Avatar
Re: front shock angle ? and short shock ?
I would think you would need a shock relocator, but check out this link and see if that helps any.
http://67-72chevytrucks.com/vboard/s...d.php?t=598060
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 04-16-2014, 06:07 PM   #3
donthekawguy
It took a couple of posts but Monroe RV Gas Magnum part #555002 is the one I need. Thanx!
66 shorty
Old 04-16-2014, 07:26 PM   #4
gofastnut
gofastnut's Avatar
Sorry! I got pushed for time doing this at, um, well, work, and thought I had the second post posted.
Jeff
C-10 Club
Old 04-17-2014, 02:00 AM   #5
familyfast64
familyfast64's Avatar
Mine doesn't have a relocated shock mount but I do have cpps lowered shock. They sell -1,-2,-3". Idon't know the post number tho. Oh and I also have drop spindles and springs like your doing
Live and let live
familyfast64 is offline   Reply With Quote
Old 04-17-2014, 11:13 AM   #6
donthekawguy
I found the Monroes on amazon for 19 bux apiece. I'm cheap so will go with them. lol
66 shorty
Old 04-17-2014, 01:41 PM   #7
familyfast64
Nothing wrong with that. Wow that is cheap.
Live and let live
Old 04-17-2014, 09:34 PM   #8
Reyals Bemus
Relocated shocks make all the difference! Here are the relocation brackets I fabricated and installed on my '64. Made out of 3/16" cold sheet steel with some gussets welded in, nothing crazy. Fixes to the frame with 1/2" bolts. These move the shocks up and out which nets a huge improvement in front end control.
Reyals Bemus is offline   Reply With Quote
Old 04-17-2014, 11:11 PM   #9
familyfast64
That's awesome! Ima have to try and make those. Would I then needed to go back with a longer shock or would my two inch lower still work?
Edit# nevermind... Duh
Live and let live
Old 04-18-2014, 12:32 AM   #10
Reyals Bemus
You can build em for whatever height shocks you want to run
