04-16-2014, 06:42 PM | #1 |
Trailing arm spring bolt.
Hey dudes I am wondering if ya'll know how to remove the bolt that holds down the spring retainer to the spring on a trailing arm. I was replacing the rear springs on my truck this past weekend and I broke the one on the drivers side. Luckily I can bolt it to the top frame for now. Any info and pics are greatly appreciated....
1960 Chevy Stepside 2wd 1966 Chevy Fleetside 2wd 1965 Chevy Suburban 2wd 1965 Chevy Fleetside 4X4 1960 Chevy Fleetside BBW 2wd |
04-16-2014, 08:47 PM | #2 |
Re: Trailing arm spring bolt.
Most of the time these are just rusted in the trailing arm. When I did mine I had to hit it with the air hammer to break it loose from the trailing arm. Then replaced it with a new bolt.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
04-16-2014, 08:51 PM | #3 |
Thank you for the info. Where cani buy a replacement bolt?
04-16-2014, 09:36 PM | #4 |
just had mine all apart,broke all bolts holding spring retainers. i ended up getting some bolts from lowes for the time being
04-16-2014, 10:07 PM | #5 |
I did the same, lowes grade 8 bolt. Both mine holding the upper were broke.
Project "i'm just going to clean up the interior and the engine bay": http://67-72chevytrucks.com/vboard/s...d.php?t=550931 |
04-16-2014, 10:10 PM | #6 |
Do ya'll know what size bolt it is?
04-16-2014, 10:41 PM | #7 |
1/2 x 13 x 5 1/2, you could probably get away with 5 inches though
04-17-2014, 07:48 AM | #8 |
Classic sells the complete bolt kit with new plates. I just installed in mine.
04-17-2014, 10:42 AM | #9 |
Thanks for the info guys...
