Old 04-16-2014, 07:53 PM   #1
HiEyeAmChris
Still working on that linkage
I appreciate all the help on this issue so far.
The guy I had scheduled to put a clutch in it noticed that the upper clutch rod was pretty misshapen and cracked.
I swung by the same yard I picked the linkage from and went back to the same truck (a '68). Its pushrod is straight while mine (see pictures) has a unique shape. I checked another '68 and a '69 - same straight upper rod. I found Brothers online who have them in stock but they show the same straight rod I found on the other three trucks while listing it as compatible with all 2WD V8 trucks.
Just as a side note I did (just for sh*ts and grins) try to fit the straight push rod. It doesn't clear the opening in the firewall with enough room to connect to the bell crank.
Does anyone know what the deal is with the upper rod I have vs the straight rod? Also if cutting a small relief in the firewall will allow the straight rod to function?
HiEyeAmChris is offline   Reply With Quote
Old 04-16-2014, 08:22 PM   #2
airdale94
airdale94's Avatar
Re: Still working on that linkage
You may have to get the bell crank (Z-bar) also. Best to find a truck with everything and grab it all. Randy (TeeItUp) may have the rod you need.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
