Old 04-16-2014, 09:46 PM   #1
Custom 68
Custom 68's Avatar
will these springs work on my coil overs?
These pics show the to and bottom could are not ground flat. I wanted to try some lower spring rate springs and found these at a low price. The current ones I have are flat top and bottom. I probably should have gotten a better spring.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 04-17-2014, 07:07 AM   #2
PGSigns
PGSigns's Avatar
Re: will these springs work on my coil overs?
I would not run them. They are not made for coil overs.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-17-2014, 08:38 AM   #3
Custom 68
Custom 68's Avatar
Thanks Jimmy. That is really what I thought as they did not match the "coil over" ones I have and have seen. They were marked as such. I will return them and get some real ones...
Dave
Old 04-17-2014, 10:29 AM   #4
PGSigns
PGSigns's Avatar
What length and weights are you looking for?
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 04-17-2014, 12:27 PM   #5
Custom 68
Custom 68's Avatar
12 inch long with a rate of somewhere between 600 and 675.
my long story is that a couple years ago I built a coilover setup for my truck. I bought used QA1 and springs. The spring are 800 or 825 lb per inch I don't 100 percent remember. They are working and have been on a few long trips but I know they are too stiff. I have done some calculations and came up with the lower values however I don't want to make that drastic of a change but want to try something different.
I am going to return these.
Dave
Old 04-17-2014, 12:32 PM   #6
PGSigns
PGSigns's Avatar
I'll look and see what I have.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 04-17-2014, 12:33 PM   #7
Custom 68
Custom 68's Avatar
awesome!
Dave
